Team Magic G4
#5101
Why
Hi guys way would i want to get the new bulkhead system . What will it do for my car.
TM Tires
www.rspeedengineering.com
www.rdlogics.com
www.tmxpress.net
www.rc4less.com
TM Tires
www.rdlogics.com
www.tmxpress.net
www.rc4less.com
#5102
TM Tires
www.rdlogics.com
www.tmxpress.net
www.rc4less.com
TM Tires
www.rdlogics.com
www.tmxpress.net
www.rc4less.com
The Speedshot front baulkhead system will give you an easier and quicker way of replacing the front diff' when you nead to. You don't have to take the whole front end apart.
The other main thing is that it enables you to alter the front roll centres by giving you three options on the upper a arm. Handy when your trying to dial in that G4s for best grip.
The other thing is...........it looks just way coooooooool
Menace
#5103
yea
#5104
Menace Im interested in that mod you mentioned for the 2 speed.
Just checked my 2 speed housing last night and its worn again.
I think a remedy to this wear is also to shim out unecessary play on the main shaft.
#5105
Originally Posted by Kodak Hodak
Hey Guys, well back with more modz, this time the front bulk head as most of you all ready know have spotted that it requires to be strengthened!!!
i didnt use epoxy, but used a product called Knead-IT as it drys like a hard clay metal substance!!!
Here is a before after shot - i am no clay modeler, but i tried the soapy water thingo and it did help a bit in the smoothness!!!
Enjoy
Enjoy
Toldya it would work and it looks neat too boot
#5106
The mod I've done is to replace the two 6/10/3 bearings with one 6/13/5 bearing. The two speed is drilled to accept the bearing as a press fit !
When drilling the housing. I have not gone all the way through. As with the stock bearings, I have left the bearing protruding from the back 0.015" to ride on the baulkhead bearing. I left a small shoulder on the inner part of the housing for the bearing to seat on. You nead to have a small spacer and shim out the resulting gap/space betwean the new bearing and the drive pin which sits inside and drives the two speed shoe cam.
Ensure the new bearing is a press fir into the housing. This is important.
I hope I have explained this ok.........it's very hard without pictures. But hopefully I should be able to furnish photo's by the weekend
Regards
Menace
#5107
Thanks BM ,get the idea and plus would be I can salvage the old housings with this mod.
#5108
#5109
guys, here's a link for blank body sketchs.. you may work your design on...
http://www.rctech.net/forum/showthre...9&page=1&pp=30
Asil
Asil
#5110
awesome
cheers man im printing them theyre really useful.
#5111
Here is my Pinion gear picture
#5112
how long have been running that pinion ???
#5113
Ed pinion gear two weeks only ,18t pinion gear aournd 2 months
#5114
Asil
#5115
How much run time in the 2 weeks ?
Im having a wear problem but its like after every 3/4 liters.
maybe it the material used in a certain batch thats softer than other batches.
