Team Magic G4
#4861
Originally Posted by Gascar 24
hi guys
tryed the ed trans yesterday
killer acceleration (watch out SA boy its quick)
was running away from andrews sirio
but still dont like oneway
like having brakes
so im going to try a front diff
will start with 50000k front oil and 10000w rear oil
on a med grip track dose that sound like a good starting point
i was happy with the steering and droop settings good grip (thanks patto)
but i have a driving style with the solid front end that i like so would like to keep that
and hope a front diff weel let me keep this style
(like to brake late !!! a real racecar driver mate of mine told me if u have the power use it in other word go hard and brake hard and that how i have been driving with thw solid front diff)
what do u think guys
let me have it
paul
like having brakes
let me have it
paul
I started with 30kf 10k rear and the 50kf with 10k and am now on 50kf and 30k rear and its definately better in and through the corners.
The 30k rear actually made the back end more predictable and controllable to me.
I too have a harder driving style with late braking and tighter lines through corners.
I also push the car to carrry more corner speed and this is were I tend to make up more ground especially out of corner with the ED.
With my Palmaris PR12 I am running 15/21 pinions with 51/46 spurs.
RCEvolution the VR12plus pipe is a wicked pipe for a technical track with a nice broad powerband and is rather versatile as it works on most engines.
Its actually very popular with a lot of top drivers in the US.
Engine wise you have lots of choices and in the price range you mention there is a lot of high end motors you could get.
Axial looks good definately ,just got one myself and its based on teh Palmaris PR12 i run at present.OS is no slouch iether and would go for the Speed version if that was a choice.
Also the JL red Dot motors by OFNA are very impressive.
But as i said in that price range the choices is too many to mention.So look at what is run locally and supported as a guide.
#4862
If I was to stay in the under $250 mark for an engine which of these 4 would be best.
Axial .12RR 3 Port Spec-1 - $275
AE Z .12R Team Spec 3 - $229
Ofna JLR Red dot .12 - $209
OS .12TZ 3-port. - $270
The Ofna JLR looks like a sweet engine but I don't know if I can push myself to trust ofna
#4863
Also I was just came very close on buying the Red Dot from Sam @Team Kamakazie(sp?), but went with the new Ninja .12 instead. I think he has the Red dot for $179, but don't quote me on that. I'm also getting ready to list a couple of mine in the for sale section. I have one left, an OS TZ 5P, and the Ninja kit that comes with pipe on the way so I can afford to part with the other two.
#4864
you can never say no to an OZ TZ.12 - they do awesome and have the grunt to keep up with Sirio's & Nova's with ease!!!
i have one, and find it very very easy to tune and hold there tune!!!
#4865
Also forgot to mention that all the killer shells posted are very inspiring. I picked up some liquid mask and I'm going to try to step out of my box and paint something alittle higher on the skill level than I normally would....
#4866
cheers, yes its good to see everyones bodyshells all loking pretty and having a go!!!
Post urs once complete - i am trying to gather a gallery of G4users for my blog, got most on her so far just want a few more!!!
Cheers
#4867
Cheers
Cheers
#4868
#4869
Absolutely! Beings I've never used liquid mask, I'm going to take my time try to get it right. I've got a new Protoform Mazda ready to go though.
#4870
hi guys
paul
paul
Why not just say watch out Rob and be done with it
#4871
help!
Originally Posted by revo523
A patto i do have the ed transmission and i try to do what you said but my dogbone doesn't reach my joint cups when i put the pins. what I'm i doing wrong here?
#4872
help!
why the pins dont line up is due to the one way bearing coming out of the housing. this is why i went for a closer inspection and the hole did not line up for the pins.
my rectification, was to use loctite super stud lock on the outer section of the bearing that slides into the axle housing. to this day it has fixed the problem. dont do it like i did, one side at a time cause it didnt take long for the other side to slip also.
you can either return the front axle to place of purchase, as TM has rectified the problem now, and they also know the earlier ED's had this problem. or you can fix it like i have and not have to return it.
so i do hope you get it sorted. i wasnt expecting this when i got my ED but i guess it happens.
#4874
Howdy guys. bit of a report on our Cup day here in Perth.
small field of cars, but top 4 or 5 are pretty quick.
so 4 qualifiers and then a 20 min final.
qualified 3rd for the Main.
had my share of problems while i tried a thing or 2 on the pinions for the ED
i tried my 15 t pinion, and now i am willing to try it no more. stripped 2 1st spurs in 1 heat. each just lasting 1/2 a lap or less. mesh was set up the same as i use for my 16t pinion, but definately a problem, or i am doing something wrong ? but after i changed back to 16t all was good again. but my clutch settings needed to be adjusted. so i did this and in the final my clutch was locking up. i came in for the first fuel stop, and the car stalled. then on the out lap i got hit and the car spun and as soon as it went backwards it stalled. so i was quick to realise it was a clutch problem , and informed myt pit guy to get the car off the ground while still moving to prevent any further stalls. man the guy was a champ and it didnt happen anymore so it was up to me to make no mistakes and keep the car moving at all times. had great pace and no major mistakes, enough to finish 2nd, and a small trophie for my rewards. thanks to my pit man.
best lap this time out was a 16.868 so thats much better this time than a flat 17. i think i did like 6 or 7 laps in the 16's and many mid to low 17s consecutively, even with my clutch problem in the back of my mind. so good day out and some real fun racing.
