Team Magic G4
#2461
Originally Posted by gtrmx
Hi Gansei!!
Actually the private message I sent you is regarding GR Racing, the Korean engine tuner.
I sent them many emails asking for pricing and method of payment for one of their OS engines, just like yours.
I really want one but did not receive any answers.
Any other means of finding and purchasing one??
Thanks!!
Thanks!!
#2462
Hey Gansei...
in one of those pics, you have a plastic cover on the bottom of your car, apparently covering the crystal on the G4 chassis.
did you fab that? or is it a part you can buy?
#2463
Originally Posted by schufflerbot
Hey Gansei...
it was protected receiver from fuel..
#2464
Originally Posted by gansei
it was made by polycarbonate piece (RC body)
btw did u mount your receiver upside down? why?
thx for sharing your idea.
#2465
Originally Posted by ickvanovs
wow u got lots of idea.
#2466
G4 weird gearing problem.
hi,I drive a G4 E-Class and i recently face some problem on my gearing system.It seems 'ok' if i drive slow or if the car is moving with its first gear.But,just the car is changing into second gear,the engine will suddenly revving high and the car couln't move any further.The gearing unit is turing fast with the clutch bell and,it stop with a sound like a clip is dropping out from its original position(due to high speed) and came back again.I really don't know what going on with it .It works fine when you lift up the car and blow it untill it change gear.But if you put it on the road,it happend again.The clutch is still in good condition and i've change the one way hub and bearing to K-Factory parts earlier when i discover this problem.And,for your information,i bought this car from my friend with no modification.He race about 4 to 5 gallon of gas with his Novarossi 5 port turbo engine,and my turn about 2 gallon with my O.S .12TR 5 port turbo(before this happen! ). Sorry for poor explaination,hope you people out there can help me to solve this problem.Thank you.
#2467
On another note i received my ED tranny from Raceday today. I can't wait to get it installed. We should be racing this weekend so I hope to give it a go. The kit is nicer than I expected. First, in the picture it is displayed with out the pinion for first gear so I ordered a 16t. It actually has one included so now I have a spare. The quality is top notch with all the pulleys lightened and hard coated black. Looks great.
Forgot to mention the clutchbell has the hole next to 2nd gear pinion for spring tension adjustment. No more hassle of having to remove the 1st spur and clutchbell for adjustments. I was lazy, and as long as it was close I would just leave it. Now I should be able to fine tune the clutch easier.No excuse.
#2468
Jacklee.. have you tried to loosen the 2-speed screw? The gap between the shoe and the S-Class housing is too small thats why the 2 speed engages way too early. When it's too tight, it wont expand. Has anyone tried different spring for the 2-speed?
#2470
I found that if you put your receiver into a ballon it protects it from everything. When you put it into a ballon you cable tie it to the car. Works find and easy to change if needed. Just another idea.
#2471
hi,...
Somebody knows if in the future ( jan 2007) the TeamMagic go manufacture a new car or new version of G4S, like G4S evo??
#2472
Originally Posted by Nelson Santos
hi,...
#2473
one way
Cheers
AK
#2474
Originally Posted by kickass
Jacklee this is your gearbox ,one way slipping. Buy a new one and do not clean out the grease ever or re grease it, just stick it in.
Cheers
AK
Cheers
AK
I just had the one way bearing fail in my 2 speed on the G4S after only a few hours of running. I have replaced the shoe cam with K14100 and have a new Kfactory one way (K1423H) on it's way as well. I had been using the Serpent one way lube on it, but never cleaned it. So you suggest running them dry as they come from the factory.
I did borrow a one way off a mate from his G4 Evo and they are different brand bearings, not sure if TM have gone to cheaper brand or not as there has been a few failures reported recently on this thread.
BB
#2475
Originally Posted by Bundy_Bear
Hi Alex
BB
BB
