Team Magic G4
#1576
Originally Posted by asw7576
I don't know...... , but I'm using Kfactory 20 & 25 pinions without problem. I suspect gear mesh problem that would result in stripping gear. Make sure you add all the shims inside the bell ( between clutch spring's locknut and bearing ) and leave the gap or play to minimum for the clutch bell. UFO clutch needs different approach or setting.
The best gear mesh I think is 19 & 25 with stock spur gears. Every gear's tooth seems to match perfectly.
The old worn out pinion was removed and replaced with a new (out of the packet) one, this pinion done nothing but strip three 2nd spur gears, i removed it and got another new one and am still running this with no sign of wear, so it has to be a duff pinion gear (hence bad qualifying times at a recent rubber national at my track).
#1577
I see.... glad that you could solved the problem
Anybody use OS TZ engines inside G4S ? I'm asking because I want to check the clearance between brake plate and engine.
#1578
ASW yes we used them for quite some time and using 18/24 had no issues.
On gear strippage. you must use the short engine screws to the engine mount at the rear. If you use any longer than the stock ones the screws that mount the engine mount to the chassis and the engine come together as they share a common hole. If you use the engine mount screw that is the next common lenght longer at the rear of the engine the screws bind together leaving about a .010 gap between the chassis and the engine mount screws. It is invisile to the eye but the mount is not secure to the chassis. The engine will shift every time stripping the gear.
#1579
#1580
Maybe I should make it clearer, only the pinion gear was changed, it was original clutch bell with same number of spacers, motor mount was double checked (was myfirst thought) even though it is never removed (I remove motor from mount, not mount from car), only this one pinion gear causes the stripping problem.
Only faults I can find with this car is:
Brake fade (cured with those pricey pads)
Battery pack - connections vibrate loose causing radio shut down, I have now resolder them.
and ....... (still trying to find another fault, and I am looking hard)
got one!! the driver
#1581
Originally Posted by Sow&Steady
I've got the OS-TZ in my G4S ... clearance seem fine.
#1582
Originally Posted by NiMo
but you've never raced it ?
#1583
i have found a program that can actually calculate the gear ratio, so u just input all ur pulleys and gear, and here is wat u will have :
- ODR Ratio
- 1st Gear Ratio
- 2nd Gear Ratio
- 1st/2nd Gear Ratio
but can anyone here explain to me wat does the ratio above means? and how are we supposed to know which sets of gears and pulleys are good match? thanks.
- ODR Ratio
- 1st Gear Ratio
- 2nd Gear Ratio
#1585
I know it already since day 1. Mugen cars also share the same hole on the engine mount : top & bottom.
I could only suggest to use 3x12mm screws for securing rear bulkheads, upper deck bulkheads and engine braces ( where the main bearings sits ). So there is no flex issue at the rear section.
#1586
#1587
Originally Posted by Car Breaker
See my Signiture, no problem at all
#1588
Hey guys, Quick question.... I'm running a stock front side pulley ... 20t rear side pulley and a 19t break pulley and running about a 3 mm split front to rear .....at what tire size would I have zero overdrive?.....and is there some formula to figuring this out...any help will be appreciated! Thank you.
#1589
RC_Alan
#1590
rc-alan, I talked to brian and Ray at the track at our last club race and brian explained it to me a little in between our heats, I'm sure it's not rocket science but I always like to get input from others....I am running basicaly the same set-up as them and just copied the pulley and tire size set-up but, I would like to try something different and run the same size tires all around...I just need to figure out what I would have to do to the pulley's to acheive that. I will see Brian, Ray and dennis this weekend but I would like to be set-up before I get to the track since this is something I want to just try before the GLC race next weekend.....Thanks for the reply
