NEW XRAY T2
#2793
Probably beating a dead horse here, but I'm Looking for a new diff, for my T2, what is the difference between the Kit Dif 305001 and the spring steel diff 305002 other then the obvious material change, can I use the spring steel diff 305002 for my T2. Didn't mean to pest just didn't wanna blow $60.
#2794
i raced my T2 last night for the first time man what a ride . yes my car rear toe is off by .05 on leftside . my hpi pro4 was off also and have alot of play around the suspension front and rear. what car i like the best is the new T2. this is my first Xray car and man what a differents i'm hooked on this car my lap times are better and the car handles like a dream
#2795
Pretty much the material change is it with the only other difference being that the Spring Steel version is not factory assembled. That of course can be good or bad depending on if you wanted to build your own diff or not.
#2797
Originally Posted by lbckevin
Brit....what are you doing up so late....staying up for superbowl...?
Some of the problems have come from guys not putting the car together incorrectly....IF we can help, it will make more happy racers...
what gears (pinion & spurs) are you guys running for stock & 19 turn @ SoCal????
48 or 64 pitch???
What final gear ratio are you guys "around"???
I might make a trip down in the next month or so...
#2798
Originally Posted by nmt6789
Hass anyone had a problem with the servo horn rubbing the top deck? I have a s9451 servo and I had to shim it to get it to fit right. I guess the only was around it would be putting diffrent shims in.
#2799
Originally Posted by beyondthepack
kewl, so I can use the 305001 spring steel diff for the T2.....so they give specific instructions how to build they're diff right? I know opions vary, just don't want to f___ it up. Thanks for your help. Hopefully Stormer has some left...
#2800
Sway bar on T2
I heard some racers are putting a sway bar up front on the T2's using other manufacturer's parts. Anyone know the part/part numbers being used?
#2801
I know Eric Anderson (EA Motorsports) used the Fk05 front sway bar and used collars to center it and used rear mounts to hold it down. If that helps any.
#2802
I used my RDX sway on the front and just used FK04/05 rear sway hardware. Like EA, I have to use collars to center the sway.
You do have to trim the RDX sway down a bit.
RDX 1.3mm bar
Dom
RDX 1.3mm bar
Dom
#2804
Originally Posted by dawgmeat
this is not my car but I think it may be 3racing I'm not sure?
www.coolcanfan.com
Cheers
Dan Chambers
#2807
Originally Posted by nnick
I think its
for 48pitch is 84 for asphalt and 87 carpet
for 64pitch is 112 for asphalt and 114 carpet
hope this helps
Nick
hope this helps
Nick
#2809
new xray t2
I seems to me that watching what everybody dislikes is a slight toe issue which I average out what people have complained about to be around ten thousands of a inch. The gap on your spark plugs in your car are more than ten thousands. That is so nominal we need to forget that and move on. In some industries that is within standards unless your NASA. This isn't rocket science. Lets help Xray with their car to stay the best in the world, and dominate this year.
#2812
I agree with jbent. These are such small margins that i dont think its worth worrying about besides the car will only go a fast as you can drive it there are very few people that are perfect. XRAY 2006 Here we come.
#2813
T2 Spring ?
T2 Shock spring Silver & gold is soft than before all spring ?
do you have spring lever ?
#2814
The gold springs <=> #308384 - Spring-Set D=1.5 (15 LB) Blue-Green
The silver springs <=> #308385 Spring-Set D=1.6 (20 LB) Light-Blue
#2815
I am a machinist. Used to work for the largest Boeing parts supplier there is. I now work for myself.
But you are correct. .010" is a very common tollerance. Nothing on an automobile is that close, except the riding components inside the engine.
I would say that overall, with the fits of the assembly of the T2 and other XRay cars, they are holding no more than .005" of tolerance. They are pretty nicely machined.
Just for reference, the average human hair is .003" thick. Same for a sheet of regular paper. So, the holes are only off a couple hairs... LOL
#2816
So, that would be like an "rch", right?
#2817
new xray t2
Look at some of the other cars on the market especially Tamiya which I have owned there tolorances are 1/16 if an inch not even close to thousands.
#2818
#2819
So the Jwerks and the PRS are the only 64 pitch spurs that fit without modification, correct?
#2820
ok guys the problem i see here is that people are not respecting others opinions and findings. what might not be important to one person might be very important to another.those of you badtalking each other shouldn't feel offended unless you're reaping the profits from the t2's being sold.let's help eachother resolve these issues wether it be fixing the car or getting a response for it's flaws if any.i'm more interested in learning more than arguing with someone i can't see.
