NEW XRAY T2
Old 05-02-2006, 11:28 PM
  #4561
C_O_jones's Avatar
Trader Rating: 11 (100%+)
Peter Robinson has a setup for the spool @ Xrays set-ups.-"2005/6 NW Indoor Champs Tour Final"
He ran it at PeelIt, indoor asphault with similar traction to Tamiya's
He ran Mod and was hooked up.
Not sure how to make a link to it tho.
C_O_jones is offline
Old 05-03-2006, 01:05 AM
  #4562
Joep's Avatar
Originally Posted by Charles
Did Xray update the shocks when the T2 came out? Or are they the same shocks as the T1?
The shocks are indeed changed.
The top nut 'lost' the notch. Which makes assembling more easy. And the piston is shorter.
Joep is offline
Old 05-03-2006, 01:40 AM
  #4563
JohnMatrix's Avatar
Thanks CO,
Ill look for it.
JohnMatrix is offline
Old 05-03-2006, 06:40 AM
  #4564
hpipro321's Avatar
if you have the old shock bodies(alluminum). u can use those bodies with a shorter shaft
hpipro321 is offline
Old 05-03-2006, 03:04 PM
  #4565
PlainOleDave's Avatar
Trader Rating: 14 (100%+)
Watch Me git shot down for this one...
I measured the Shock shafts from the shorter of the T1 and they appear to be the same as the new T2 shafts.
PlainOleDave is offline
Old 05-03-2006, 05:08 PM
  #4566
ChrisP's Avatar
Could be...
The original T1 came with shorter shocks in the front, but they were later changed to all one length in the Evo2...
Now Xray has gone to a shorter length shaft, so it may be similar(or the same length even) as the original T1 shafts..
ChrisP is offline
Old 05-04-2006, 05:30 AM
  #4567
Trader Rating: 208 (100%+)
Who makes a spool for the T2? I do not really want to spend the money on a multi-diff that I would only use as a spool.
dodgeguy is offline
Old 05-04-2006, 05:46 AM
  #4568
Spud_J's Avatar
TIR - Titanium Racing in the UK are just about to release one. I ran the prototype at the weekend and it was really good. Around 5g lighter than a multidiff and also seemed a little easier on the blades.
This one is all alluminium however in the near future they will be bringing out a version with lightweight delrin outdrives.
Guessing they should be available in the US through Schumacher who are the distributors
Steve
Spud_J is offline
Old 05-04-2006, 06:40 AM
  #4569
hpipro321's Avatar
i have also heard the corralys fit
Old 05-04-2006, 08:23 AM
  #4570
Kyle Wilson's Avatar
Trader Rating: 17 (100%+)
I think that BMI is working on one as well... may be Jason can elaborate on this?
Kyle Wilson is offline
Old 05-04-2006, 02:30 PM
  #4571
pucho's Avatar
totaly diferent design, it's not eaven close.
pucho is offline
Old 05-04-2006, 03:07 PM
  #4572
Iceracer's Avatar
Do you think a novice would be wise to buy a T2 or would a T1FK05 be as good a choice? How would you compare the two?
Iceracer is offline
Old 05-04-2006, 03:13 PM
  #4573
If money is not an issue, get the T2. The 05 is a good car, but it's harder to work on. Plus it (T2) works well. I just ran mine for the first time last week and it was great. I used the kit setup too.
DOTMAN is offline
Old 05-04-2006, 03:16 PM
  #4574
Iceracer's Avatar
You've got 152 pages of great information here. Are the bugs all worked out of the T2 design and production? parts availability?
Iceracer is offline
Old 05-04-2006, 03:26 PM
  #4575
hpipro321's Avatar
if you are a novice...i would definatly recoment the fk05...it is a much better car for a beginner because the chasis is much stronger and the car is extremely easy to work on....so is the t2 but the chasis is weak in the front...the fk05 is your best bet
