NEW XRAY T2
#4171
Originally Posted by stormperson
I have never had problem with the shocks leaking. If they are leaking it is most likely due to a bad o-ring not the shock body. Although I will say that having a fresh mold for the new shock bodies probably is better than the shock body that was coming out of the old mold for the 05...
#4173
Nope mine are fine also...no leaking; they work great.
#4174
Suspended
I have never had any leaking problems until today...
my car was sideways at the end of the straight and was t- boned twice. A shock in the front and rear blew up. It was a huge oil leak...
#4175
Then there's the rebound issue.
#4177
Length T2 Shocks
Can anyone give me the length of the Xray t2 shocks when fully extended please...
Many Thanks
Many Thanks
#4178
Originally Posted by R/C Anonymous
I know the 30wt oil definately has enough for all 4 and then it has about 2/3 of a bottle after that left.
#4179
Trader Rating: 51 (100%+)
teamgp ygpm question for ya
#4181
#4182
Originally Posted by rmargiotta
If you read and follow every step in the manual about the shocks, and learn how to bleed them properly, these are some of the easiest to build, fool-proof shocks that you will find surprisingly easy to maintain.
#4183
Originally Posted by DennisNyholm
I'd have to agree. I rebuilt my shocks on my XXX-S a few times and it seemed that every time, they had air in them. WHen I built the T2 shocks, I went relatively quickly and only one had air in it. It was easy enough to pull apart, add more oil and bleed it again. I was very impressed on how smooth they were and how great the adjustability of them are (i've never had adjustable shocks before). That is a pretty cool feature!!
IMO,the problem with the plastic shocks,after a couple of runs,oil starts to seep VERY slowly from the plastic end- cap around the o-ring area.
The plastic shock bodies and end- caps don't hold tight enough together to compress the o-ring enough to stop the leakage.
When I switched to the aluminum bodies,the plastic end- caps held on tighter making a better seal for the o-ring stopping the leakage.
#4184
Heck, while we are on the subject of aluminum parts for the T2, can i get those plastic shock pieces in aluminum (the O-ring holder)?? It would LOOK so much better to have it in all aluminum. And has anyone found another source for the o-rings other than from XRAY? They are smaller than AE/Losi o-rings.
#4185
Xray made sure you had to buy replacement parts from them.
