NEW XRAY T2
#3616
Originally Posted by Michael Barch
I use the Losi 32.5 oil, so far so good.
This may also be why your car is diving in so much. With too thin of an oil wt, the front will dive and the rear will lift up extremely quick, overload the front springs and transfer more weight than needed on corner entry. You might want to change the oil wt first and test the car.
I still think you need to flatten the rear arms out though. I've only seen pro-squat work well for corner entry steering and exit rear end grip with a spool setup on very low grip asphalt. On carpet with foams and much better traction, even with the front steering into the corners well, the pro-squat will probably cause the car to scrub too much speed on corner entry for fast lap times.
#3617
Well the T2 gives you 30WT oil...its thicker than the stuff XRAY gives you.
#3618
Alright I will glue the edges of the foams, should I glue both the outside and inner edges?
I don't think I got rim stickers.
You can make them really cheap and easy with a piece of Monokote used for covering the skeleton of R/C planes, and easily bought from any LHS. You can buy a small piece and get ALOT of "stickers" from it.
#3619
Eh. Alright
What can I do without changing oil?
Take out the .75 shim of the rear?
Stiffen up the front springs even more...
#3620
Eh. Alright
#3621
On all the shocks?
#3623
Originally Posted by teamgp
I'm not sure what you mean, but the XRAY T2 comes with XRAY 30wt oil which is again more equivalent to Losi 50wt or 55wt.
Dom
#3624
#3625
#3626
Originally Posted by RobertV
Then why is Pro-Squat recommended in the "Basic Set-up For Foam Tires" setup sheet included with the T2?
The thin oil is probably the issue.
#3628
Okay, so I need to put XRAY 30wt oil in my shocks (I used all mine when trying to build and rebuild and do agian and agian, now I learned how) so I will have to buy some. If they don't have it what kind can I buy? Losi 50wt?
Then can I go 2 pistons open still?
One last thing, can I keep the rest of my setup how it is? The Rear Squat, should I change all of them so there at 0*? On the basic setup sheet it shows -.75 all around and 0 in rear.
#3629
I believe Larry's has some oil in stock.Try to stick with the Xray oil if you can.
I THINK that the Losi 50 wt still might be too thin.There is really no good way to tell.
#3630
You can use Losi 50-55 wt oil to come close to Xray 30 wt .
You can go back to the 2 hole pistons with the thicker oil.
Still need to stand the shocks up ....try one hole at a time to see the difference each time you change. Try the oil first, drive it and then make another change. One change at a time.
Good Luck....
Good Luck....
