NEW XRAY T2
#2956
Originally Posted by James
eagerly awaiting the new KO PROPO low profile server... next month, fingers crossed
James
James
Steve Wang
#2959
Originally Posted by SpeedTech
Sorry to get off topic a bit. I think we got a press release on this new KO servo, and if I remember correctly, it has well over 100 ounce of torque (I think the Futaba is right around 85) so good power in that small package I'll go look for it tomorrow (it's in my mail somewhere) and I can confirm the spec.
Steve Wang
Steve Wang
http://www.rctech.net/forum/showthre...58#post2118158
#2960
that Larry? if so your alum rear hubs for T2 are awsome!!
#2961
Originally Posted by Lycan
Hi all,
Is there an error in the setup book?
Under damping they list the same result using thin oil and thick oil for the rear shocks (page 32). Can someone clarify? If they are wrong, what would be the result of thick oil in the rear of the car?
Cheers
Lycan
Cheers
Lycan
Also, with stiffer springs it is common to go up on the oil weight to keep the cars rebound effect the same. Rule of thumb is to go up 5 wht on oil for every 5lb of spring. It isnt exact, but its a good starting point. Unless gaining rebound is part of the reason for going to a stiffer spring, in which case the oil would be left the same.
#2962
Very good post Cory, you make me think in a more rational way. Thats how I learn, thanks.
#2963
Originally Posted by taz5176
first heard from hebiki last wk, same specs as wat u got?
here are the specs for ease of viewing for T2 drivers looking for a new low profile servo:
Specs:
Model Name: PDS-2413 ICS Low Profile Digital Programmable Servo
Item # 30044
Speed: 0.10 sec
Torque: 118 oz-inch (8.5Kg-cm)
Weight: 44.8g
Length: 41mm
Width: 21mm
Height: 25.4mm
there's a link in my signature for ko propo servos.
#2964
Originally Posted by Hebiki
thats the same press release. i just get mine earlier.
Specs:
Item # 30044
Speed: 0.10 sec
Weight: 44.8g
Length: 41mm
Width: 21mm
Height: 25.4mm
Specs:
Item # 30044
Speed: 0.10 sec
Weight: 44.8g
Length: 41mm
Width: 21mm
Height: 25.4mm
Unless it is comparable in price I dont know why you wouldnt just go with the Futaba S9550.
#2968
Originally Posted by STLNLST
Maybe it's faster
Futaba is .11
KO .10.
so your looking at double the price for .01 in speed and 33oz torque. If the $169 price tag is correct.
#2970
Originally Posted by Ill Factor
it is by .01
Futaba is .11
KO .10.
Futaba is .11
KO .10.
169 for a KO, and Tower offers you 2 9550s for 140....
I think I ll go with Futaba ........................ and keep the change you filthy animal hahahahaha (awesome outtake from Home Alone)
