NEW XRAY T2
Old 01-17-2006, 08:48 PM
  #1921
Twin 1 Kevin's Avatar
Default Sway Bar
I would like to know if anyone is running a swaybar on the front of the car. Since X-Ray didn't release them yet...I wanted to know what I need to do to run one.
What size is the ball cup on the front arm?
Is it necessary to run a front bar on this car on Carpet?
Thanks!
Twin 1 Kevin is offline
Old 01-17-2006, 08:50 PM
  #1922
i like running my tires on the big size (60mm) just so i dont go though them as qiuck what should my droop be?
zinger77 is offline
Old 01-17-2006, 08:54 PM
  #1923
Thanks!
Some of the guys here in Dallas are using the 05 rear sway bar and it is working out great. You do not need it though.
mtc3od is offline
Old 01-17-2006, 09:13 PM
  #1924
Trader Rating: 21 (100%+)
when ralph burch was running the pre-production car he did indeed use a T1 rear sway bar on the front and had pretty good luck with it.
peter_robinson is offline
Old 01-17-2006, 10:02 PM
  #1925
imprsme's Avatar
Trader Rating: 91 (100%+)
Also if your local hobby shop sales airplanes you can get piano wire from there in 1.2mm or whatever size you want and then get some threaded rod while you are there.
Then use the long shock ends that were on the shock parts tree to thread onto the threaded rod.
Then bend the Piano wire to fit...
Look at some pics from the Novak race there are sway bars on them cars
You will get the idea.
imprsme is offline
Old 01-17-2006, 10:55 PM
  #1926
lbckevin's Avatar
Trader Rating: 107 (99%+)
Ran the car tonite in stock at Socal...Wow, what steering. We run high bite asphalt, rubber tires...I am very impressed with the kit. Did find out , I will need to run the tamiya wheel hubs, cuz the stock rims hit the shocks ...Oh well.
Ps. You may need to shrink wrap the cvd pins, I had a hard time keeping them in even with locktite. I may grind a flat spot to have the set screw hold better.
Kevin
lbckevin is offline
Old 01-18-2006, 12:55 AM
  #1927
RCknight's Avatar
Default Anyone....
know if the new battery brace will be out soon? I'm in need of a brace bad.
RCknight is offline
Old 01-18-2006, 02:22 AM
  #1928
RCknight's Avatar
Default Here are some pics of my ride.
It was the neatest I could do to get the GTB to fit. Not much space, but it all will fit just fine.
RCknight is offline
Old 01-18-2006, 02:36 AM
  #1929
Frank McKinney's Avatar
People have posted that the FK'05 brace will work if you flip it 180 degrees.
Frank McKinney is offline
Old 01-18-2006, 06:20 AM
  #1930
Exactly....
Miu Miu is offline
Old 01-18-2006, 06:21 AM
  #1931
Giuseppe d.'s Avatar
Here's my T2 with brushless sistem on it..
Attached Thumbnails NEW XRAY T2-img_1471.jpg   NEW XRAY T2-img_1472.jpg   NEW XRAY T2-img_1473.jpg
Giuseppe d. is offline
Old 01-18-2006, 06:36 AM
  #1932
teamgp's Avatar
Originally Posted by James
I'd be interested to see how people are mounting their transponders (when mounting them on/in the bumper) particularly where your putting the wiring, etc.
could i cut a small section out of my foam bumper and have the transponder under the plastic bumper 'down brace' thingo.. ? pics also appreciated.
Here ya go. This was done with a standard hobby knife.
teamgp is offline
Old 01-18-2006, 06:57 AM
  #1933
VenomWorldOrder's Avatar
Originally Posted by Miu Miu
Exactly....
that's if you can get your hands on a fk05 strap. i think they are on back order with the motor guards
VenomWorldOrder is offline
Old 01-18-2006, 09:25 AM
  #1934
i have them both..cos i have the fk05 as well...
Miu Miu is offline
Old 01-18-2006, 11:39 AM
  #1935
Mike Mandio's Avatar
Originally Posted by Rob Phillips
DW, where did you get that 85* counter sink from? Can't find one locally. Can you bring it to the track Sat? Thanks
Metric screws use a 90 degree countersink. I got mine from McMaster Carr - www.mcmaster.com
Mike Mandio is offline
