Xpress Pro Setups Needed
Just wondering if anyone has some xpress pro setups for assphalt? The track I run on is pretty tight and smooth. I will probably be using sorex 32's. Thanks for your time, Blake<[email protected]>
xpress setup
I donīt know what xpress do you have, but you could trie starting from the old Mike Swager car: http://www.rc-xpress.com/dri/mike-s01.jpg
i used to run one of those with the red alum all over it. they can be quite challenging to set up some times because of the extreme adjustability. the front end can be a little fragile sometimes too. you might wanna think about replacing all the ball studs and ballends with rpm stuff and matching ballends as the factory stuff is kind of soft and pulls out too easy. it took quite a bit of work but i finally got it all running pretty good. the next prob comes down to availability of parts. overall it is a fast carpet car, very pretty, just get online and you will have to be your own warehouse as no one else will probably have the parts to fit. good luck and i am open to any questions. cya, josh
