Tamiya TB-Evolution III >
Old 10-28-2002, 01:15 PM
rc-zombies's Avatar
Default Tamiya TB-Evolution III
The EVO-III thread is going to start sooner or later...so it might as well be now...since the car is due for release in a couple of months. Can't wait to get my hands on one...
rc-zombies is offline
Old 10-28-2002, 02:09 PM
ruf
ruf's Avatar
Getting one ASAP. That will be my a$$-kicking car.
ruf is offline
Old 10-28-2002, 02:28 PM
JohnA's Avatar
Does anyone know if Tamiya have done anything to improve the spur gear access? I heared the evo III will use regular spur gears, that's a start!
JohnA is offline
Old 10-28-2002, 02:31 PM
ruf
ruf's Avatar
The Evo3 will use a spur gear adapter so you can use other company's gears. I don't see a point in this since the 88 hardened Tamiya is not that expensive and very good as well. Anyways, by eliminating the TGR gearcases and the aluminum bulkheads, the spur gear should be easily accessed by removing 6-8 screws like the original TB01.
ruf is offline
Old 10-28-2002, 02:35 PM
rc-zombies's Avatar
Removing the aluminum bulkheads and redesigning and lightening other parts resulted in 40gr. less weight. Narrower chassis than the TC3... The EVOIII is going to be Fast!!!!!!!
Old 10-28-2002, 04:44 PM
TRF414M's Avatar
TC3 in graphite chassis. You should get the parts from Square for changing into TC3 Steering post.
TRF414M is offline
Old 10-28-2002, 04:47 PM
rc-zombies's Avatar
I have a TC3 already...what's the advantage using the TC3 steering post vs. the stock ones?
Old 10-28-2002, 06:06 PM
what gear cases are they using the tb-01 or a newer design
sportracer is offline
Old 10-28-2002, 07:02 PM
ruf
ruf's Avatar
New design based on TB01 gearboxes which are much freer/faster than TGR gearboxes.
ruf is offline
Old 10-29-2002, 12:14 PM
Aluma's Avatar
i believe he want to use the WHOLE TC3 steering system... it doesnt flex like the separate plastic ones all tamiyas have...and I has very good ackerman which you can adjust simply. Several other High end cars use the TC3 steering system...like the Alex Racing Barracuda can be adjusted to it...I think I saw it on a Pro 3 once as well.
Aluma is offline
Old 10-29-2002, 12:15 PM
Aluma's Avatar
Oh, yeah. ... I tried to put it on my tbevo2 but it didn't fit right :P
the rack needs to be longer....oh well...
Aluma is offline
Old 10-29-2002, 12:19 PM
rc-zombies's Avatar
The new Evo-III uses an aluminum steering set like the 414m2's
Old 10-29-2002, 03:56 PM
TRF414M's Avatar
I wish they just use the same system as 414M2 because of the slop.
Barracuda has a lot of slop problem and I switched to TC3 Steering system. First you need to order throught Futaba Sangyo in Japan for the TC3 steering system for Barracuda. Then use all the hardware of TC3 or get the OVA TC3 Aluminium Steering. But one thing that you have to pay attention to, you need to modify the hole for the steering knuckle. You need to drill an extra hole in front of the original knuckle. This will give you the full travel distance of the steering. If you use the original setting, you cannot get the full distance. Good example is at K-model barracuda
TRF414M is offline
Old 11-01-2002, 08:40 AM
rc-zombies's Avatar
Old 11-03-2002, 06:04 PM
TRF414M's Avatar
I saw the RC World December Edition.
For the change of the Spur Gear, you have to take out the rear diff cover, then take out the shaft from the rear and finally lift the upperdeck and remove the Spur Gear. This time, they will give you the adapter right away. You can also use the A-arm from TRF414M2.
They adopt similar steering system as TRF414M. This should elimnate some of the slop of the car. They have a graphite plate at the bottom of the Steering post.
TRF414M is offline
