Tamiya TB-Evolution III
#6796
this is the Square gear box
#6797
hey therealshark how much do those aluminium gearboxes weigh compared to the standard parts.... are they worth the extra weight??
#6798
the aluminium gearboxes are about 30 gramms more than the plastic ones if you choose using them front and rear.
I īm using them for more than a year and I have to say itīs one of the best custom parts for the EVO III. There are no more stripped screws and they donīt twist like the plastic parts. This also means you will have a much stiffer chassis. In fact I ended up throwing away the plastic chassis brace as the chassis was to stiff now for my liking and so youīre also saving some weight again (about 10gramms).
#6799
I have the square gear box in front and the light weight shaft but you still need shimming, at first I didn't shim the gears but it was running fine until I tried my new 12*1 High Torque corally black that thing is torque monster!! I started stripping the gears again under full throttle!
I know I'm not saying anything new but shim the gears, get a good mesh and should be fine!
SEE YA
SEE YA
#6800
Hey all,
I have decided to stop running my evoIII on foam tires and will be running it exclusively on Tamiya Type A tires on Ozite. if any of you wouldnt mind sharing a set-up to start with-I'd appreciate it.
One issue I am having is getting steering throw out of the car. Running all standard equipment (helios, KO digi servos, etc.) I am maxed out on d/r and expo on my radio for foam tires. I can only imagine I will need way more steering to run rubber tires on carpet, right?
Thanks,
Ray
Thanks,
Ray
#6802
Re: sqare gear box
This might sound like a silly answer but the manufacturer of the Square Gear Boxes for the EVO III is a Japanese Company called 'RC Square'. You should still be able to order these through Rainbowten (www.rainbowten.co.jp) if they are still in production.
Originally posted by therealshark
about my last post i was wondering who makes the square gear boxxes and where i can get them?
sorry if i caused any confusion
mike
mike
#6804
Originally posted by rayhuang
Hey all,
Thanks,
Ray
Hey all,
Thanks,
Ray
I had the same problem with the steering throw (could'nt get enough steering even with the one-way). I swapped the C1/C2 knuckle positions (opposite of the kit instructins) and found the steering I was looking for.
I'll send you my rubber setup tonight when I get home. Its based on CS27's on high grip Ozite.
Jimmy
#6805
I plan on running at the Reedy race in may, I have evo III SE straight out of the box. I want to know if the evo III is still competive? How well does the LW arm kit work? Or should I get an evo IV?
#6806
I'm curious about the LW suspension too...I just picked it up last nite and haven't put it on the car yet...was wondering if anyone else tried it too
#6807
I am looking to get an Evo III Surikarn Edition. I can't find one online. And they have been discontinued through my hobby shop. I don't really want to build one from parts but if worst comes to worst I will. Can anyone help me in my search for an EVOIII?
#6808
Check on eBay, they usually have unopened normal Evo III's for around $380, then if you want just buy the surikarn parts if you're desperate.
#6809
Or you could shell out $550 for this, signed by Surikarn, Surikarn Evo III kit. http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW.
Or a little less for this http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
#6810
