Tamiya TB-Evolution III
#6286
Originally posted by f1larry
I usually buy 3 packages at a time. if you get them from rainbow Ten they are less than $4 bucks a set. if you order enough little things its a great deal even with shipping.
Too bad they don't just sell the hinge pins that we all bend I am starting to get a huge collection of brand new never used hinge pins for the up rights.
#6288
THE PART NUMBER FOR THE NEW SHAFT IS 53686. THEY ARE PRETTY REASONABLY PRICED IG GOT MINE FOR 16 CANADIAN.
#6289
Hey Trev
there is no new part number for the new gears. It is the same as before. The problem now is to find a place that sells the new type gears - I think peter grayson got his batch from rainbow ten
#6290
So, who actually raced their Evo? I bought an TB-Evo III from a German hobby store. The previous owner has bought the option chassis, shaft, motor mount,and enough parts to build two cars! I built a one-way diff yesterday for the car (in case I want to throw it in one day), dug around the box and found enough parts for another one way diff! So, I started building the SECOND EVO III! Came across a tiny problem though, some of the parts didn't have a extra (like the ball bearings for the steering linkage), so I'll pay my hobby store a little visit for some parts to complete the second car. I have the first Evo setup with ball diffs, front and rear sway bars (don't need them though) and a modified motor layout (Trinity D5 9T single, 37T pinion and 88 spur, and Trinity 3300 NiMH Vis- Extra Matched cells).The second Evo may be just stock (Trinity P2K Pro2, 3000 NiMH cells) or I'll try to see if I can turn it into a rally car. I am trying to locate a track here in Germany to race against. We have a small course here on post (built on a rubber cork surface, tennis court), but it has hardly no traction, but it is good for drifting though!
#6291
Originally posted by TJ
Ha guys what part number to I ask for for the new one way gear and the 2mm longer shaft. Also how did you find the parts page at rainbow I have been to the site many times but I have difficulty finding what stock they have.
#6292
hey guys alittle of target but when u assemble the evo 3 you get a choice of a part called J3. if u run stick packs u have to run it one way and if u have saddles the other way. i currently run sticks and am looking to buy only 1 saddle. ive looked at the part and if i reversed J3 it looks like id hit the servo. is this because my servo is too big(s3003 futaba) or do u guys have ne advice. pictures would be a help to.
djb
djb
#6293
Chop the triangle shaped tabs off that part...I did that and now I can fit an IPCv7.1 &, JR XS300 & a standard JR racing servo (not the smallest electronics)
You might have to drill out a hole where the motor brush may hang out a bit
My first upgrade is probably gonna be the alluminum upper deck supports
#6294
I just fitted a new castle wall to the blue car I was reassembling last night... didn't have to cut anything off. Some cut the protruding tabs flush but only if you need more room for your ESC/RX. S3003 fits fine and just clears the tabs.
#6295
Am running everything from (1) plastic castle wall, (2) nothing "commando" , (3) Tech nylon T-bar, (4) alloy I-beams.... can't tell ANY major effect from any of them.
Just got a countersunked top deck... hmm interesting.
#6296
Wc reckons not to run the aluminium upper deck supports but can u guys still give me a part number for that piece anyhows. And who would sell it. rainbow ten or speedtech??
#6297
Alloy bits always looks nice though.
But they don't stop your wires from rubbing the shaft.
Damned, hobbymania seems to have updated their site & lost their "Square" options page with all the pix.
R10 offers these in stock:-
3733437350231,Square,1400YEN,STB-7 TB EVOLUTION 3 ALUMINUM TRANSPONDER & SERVO STAY,
3733437350237,Square,5460YEN,STB-1 TB EVO 3 CARBON PRO CHASSIS,
3733437350239,Square,2400YEN,STB-6 TB EVO 3 TITANIUM COATED SUSPESNION SHAFT,
3733437350240,Square,1400YEN,STB-3 TB EVO 3 FRONT CARBON STAY,
3733437350241,Square,1540YEN,STB-4 TB EVO 3 REAR CARBON DAMPER STAY,
3733437350243,Square,3600YEN,STB-35B TB EVO 3 ALUMINUM KNUCKLE,
3733437350244,Square,3500YEN,STB-36B TB EVO 3 ALUMINUM FRONT HUB CARIER 5.5,
3733437350246,Square,3200YEN,STB-50B TB EVO 3 64 TITANIUM DOG BONE,
3733437350248,Square,2500YEN,STB-20T TB EVO 3 HEATSINK MOTOR MOUNT,
3733437350250,Square,3500YEN,STB-35T TB EVO 3 ALUMINUM FRONT HUB CARRIER 5.5,
3733437350254,Square,800YEN,STB-30 TB EVO 3 DELRIN SUSPENSION BALL,
3733437350255,Square,1200YEN,STB-27S TB EVO 3 CARBON DIFF SETTIG PALTE,
3733437350257,Square,1400YEN,STB-21B TB EVO 3 HEATSINK UPPER MOUNT BLUE,
3733437350263,Square,1400YEN,STB-7B TB EVO 3 ALUMINUM TRANSPONDER STAY BLUE,
3733437350264,Square,2600YEN,STB-37B TB EVO 3 ALUMINUM REAR DECK HOLDER BLUE,
3733437350265,Square,2600YEN,STB-37T TB EVO 3 ALUMINUM REAR DECK HOLDER TITANIUM COLOR,
3733437350280,Square,2400YEN,STB-25B TB EVO 3 CENTRE POST SET,
3733437350282,Square,3500YEN,STB-142T TB EVO 3 REAR HUB 2.5,
3733437350288,Square,1400YEN,STB-7R TB EVOLUTION 3 ALUMINUM TRANSPONDER & SERVO STAY,
3733437350291,Square,1400YEN,STB-21R TB EVO 3 HEATSINK UPPER MOUNT RED,
3733437350293,Square,3600YEN,STB-35R TB EVO 3 ALUMINUM KNUCKLE,
3733437350294,Square,3500YEN,STB-36R TB EVO 3 ALUMINUM FRONT HUB CARIER 5.5,
3733437350295,Square,2600YEN,STB-37R TB EVO 3 ALUMINUM REAR DECK HOLDER TITANIUM COLOR,
3733437350297,Square,3500YEN,STB-142R TB EVO 3 REAR HUB 2.5,
3733437350327,Square,3500YEN,STB-43B TB EVO 3 REAR HUB TOE IN 0.5 BLUE,
3733437350328,Square,3500YEN,STB-43R TB EVO 3 REAR HUB TOE IN 0.5 RED,
"Center Post Set" but dunno if its red, green or blue.
#6298
hey Wc whose that R10 u mention about. Are they are company like hobbymaina or like speetech?? and should if file the battery holes down if I want to run saddle packs??
#6299
Rainbow Ten
I do my CF sanding under running water - Sniffing carbon dust is bad for your health. Just use a large file and sandpaper, don't need to bust out the Dremel.
Might want to round all the other edges too... was mucking about on Monday with a brandnew 3mm chassisplate, boy its edges were SHARP!!
#6300
i have a few parts on my car which i don't know if there tamiya or something, can anyone tell me who make 3x28mm blue turnbuckles, with the part you put the turnbuckle wrench on 3.5mm big
