Tamiya TB-Evolution III
#5882
hey i have a oneway houseing i you want
#5883
Originally posted by izzyracer
Does anyone have an Extra EVO 3 One Way that they are selling or where can I get just the one way assembly for my TB02
PM me with you e-mail address, and lets talk
#5884
new gears
has anyone got the part no for the new gears
#5885
Re: new gears
#5886
Rick dude,
when u built your drive train up with the new gears and prop, did you take any further precautions or do anything like shimming becasue at first i got a bind in the gears
thanks mate
Tarnj
thanks mate
Tarnj
#5887
I just put it together and shimmed so there was no movement in the gears but not so they were tight. Rick
#5888
hi, has anyone of you bought and tried the blue convertion kit of the evo III? does it improve the performance of the car or it's just for the looks? i'm considering of getting one but would like the opinion of others before buying it, tnx
#5889
i got it its just for looks mostly the only impovement is the motor mount it comes finned it will keep the motor cooler.
#5890
It does give you the blue shaft, which is 2mm longer than the original shaft and it fixes the front oneway/bevel gear stripping problem.
It also give you a slotted motor mount which is slightly lighter and provide additional cooling surface
However, if you are interested in performance upgrade alone, get the new light weight shaft. It's also 2mm longer thus fix the oneway issue and lessens your drivetrain rotating mass.
#5891
so the shaft on the blue conversion is the same size as the new lightweight shaft?
#5892
#5893
Originally posted by jeffreylin
Mostly just looks. It's not even complete as it does not include the upper suspension link blocks nor the washers and ball ends of the stabilizer.
#5894
hey sorry for all the questions.
re: shimming
which shimms do you use and were do you place them? i read on the tamiya website that this guy shimmed his diffs away from the pinion. is this what you done rick?
how ? which shimms?
could u post me a pic if poss.
thanks alot
Tarnj
re: shimming
how ? which shimms?
thanks alot
Tarnj
#5895
re: shimming
how ? which shimms?
thanks alot
Tarnj
re: shimming
how ? which shimms?
thanks alot
Tarnj
