Tamiya TB-Evolution III
#5431
Originally posted by RC Driver Gary
It's now time for Tamiya to announce an Evo 4 as I just bought a Surikarn today
Welcome aboard!
So are you saying that you didn't look on the Tamiya New Release pages this morning, before the trip to the Hobby shop? I
#5434
Originally posted by lbckevin
Hey guys,
I need a Tamiya track setup and / or a parkinglot setup for next week at TCS in Newark , CA
Help me Help me ......I am slow.......
Rod?
Hey guys,
Rod?
Front:
upper shock: furthest out on tower
lower shock: kit stock
spring: Tamiya Yellow
oil: Tamiya 500wt
piston: 2 hole
swaybar: red
camber: -1.5
toe: 0 degree
downtravel: 6mm measured from lowest point of suspension arm directly below outer hinge pin to setup board.
rideheight: 4.5mm
kickup: Flat - No shims under the front suspension block
wheelbase: Per kit instructions (6mm in front of arm and 0mm behind I believe)
Camber links: Middle setting with 5 mm of shims under the inner ball link. (Surikarn mounts)
Front One-Way/Spool
wheel spacer: 0.5mm (blue) on the front wheels only.
Rear:
upper shock: one hole in from furthest out on tower
oil:Tamiya 400wt
piston: 2 hole
swaybar: red
Camber: -1.5
Camber links: long position (inner hole), 2mm of shims under the inner ball link mount. (surikarn mounts)
toe: B block in rear
downtravel: 7mm measured from lowest point of rear hub carrier (near the back) to setup board.
rideheight: 4.5mm
anti-squat: Flat- no shims under the rear suspension blocks.
Tires: Take-OffCS27
I hope this helps and let me know if I forgot something.
#5435
Originally posted by rtypec
Front:
oil: Tamiya 500wt
piston: 2 hole
swaybar: yellow
camber: -1.5
toe: 0 degree
rideheight: 4.5mm
Front One-Way/Spool
Rear:
oil:Tamiya 400wt
piston: 2 hole
Camber: -1.5
rideheight: 4.5mm
Tires: Take-OffCS27
Front:
oil: Tamiya 500wt
piston: 2 hole
swaybar: yellow
camber: -1.5
toe: 0 degree
rideheight: 4.5mm
Front One-Way/Spool
Rear:
oil:Tamiya 400wt
piston: 2 hole
Camber: -1.5
rideheight: 4.5mm
Tires: Take-OffCS27
#5436
Originally posted by A-Ko
What motor, gearing and body have you been running?
gear: 96/31 for 8.05
motor: Orion V2 10x1
body: Proline Stratus 2.0
also added the swaybar color to my previous post, they're red.
#5438
Is the easiest way to change spurs to pop the rear gearbox off by removing those 4 screws? Looking at the manual and the car itself that's how it appears.
#5439
foam setup
hi dose anyone have a good foam setup?
thanks peter
thanks peter
#5440
guys seen a few people running with no centre peices in their cars. what effects will this have on your car? be less stiff..
my mate does it on his sd sometimes too.
also i think reinhard did it when he was testing a 2-3 piece prop.
thanks guys
Tarnjit
thanks guys
Tarnjit
#5441
thanks guys
Tarnjit
thanks guys
Tarnjit
#5442
Re: foam setup
thanks peter
thanks peter
-Sushi Boy
#5443
Hey Mikey, I think I like it! Ran my evo for the first time last night with the setup that was on it when I got the car...very soft for carpet (my thought) and the car was really good. I managed to wual 3rd and finish 2nd to another evo. I did buzz a ring and pinion, but I smacked the hell out of that board. It thought twice about getting in my way again after that It'll be interesting to see what this car does with a stiffer setup and a 19turn.
#5444
Jason, I looked through your pinning piece, and had a question. How the heck did you get that battery tab to get in, not push out the back side, and then get the bearing in? I tried wrapping the tab around the bearing first and inserting it...no go... I tried putting the tab in and pushing the bearing in..no go. Any suggestions?
#5445
Gary I used the bearing to shape the tab, then closed it in a little smaller and put it in the tranny case. Then you can spread it out and (here's the trick) start the bearing on the OPPOSITE side of the ends or opening on the shim. If the shim is a "C" shape, then start the bearing opposite of the opening of the "C". Then work your way around until the bearing is fully inserted. It should them slide all the way in ( ). The first time isn't particularly easy but after that it's no problem because the shim has taken the correct shape.
