Tamiya TB-Evolution III
#5416
Blank Setup Sheet
Umm Hey Kevin, I can't find an image of a blank EvoS setup sheet that I can work with. Anybody here have one? Thanks in advance.
#5417
#5418
Re: SETTING
Originally posted by Albino2000
Here is my setup. I use it on EVERY indoor-carpet track. And it always works very good.
Front:
Spring: AE yellow
oil: 70wt
piston: 2 hole
swaybar: blue
camber: -1.5 to -2.0
toe: 0 degree
caster: 4 deg
kickup: 1mm of shims under the front suspension block
Camber links: Long setting with 2 mm of shims under the inner ball link. (Surikarn mounts)
Ball Diff
Jaco Double Pink/Orange tires with TQ Purple on inside half.
Rear:
Spring: AE purple
oil:60wt
piston: 2 hole
Camber: -1
Camber links: long position, 4mm of shims under the inner ball link mount. (surikarn mounts)
toe: 1 degree (2 deg hubs and C block up front and A block in the rear.
anti-squat: 3mm of shims under the front suspension block and 2.5 mm of shims under the rear suspension block.
Jaco Double Pink Tires with TQ purple on the full width of the tire.
Motor: Orion V2 mod 10x1
body: Protoform Alfa 2.0
-Sushi Boy
#5420
Re: front one-way gear
Originally posted by 1shnot
anyone try the metal front one-way gear from leochan?
if so any results?
thanx alot guys
joon k
if so any results?
thanx alot guys
joon k
#5422
Blue shaft?
What do you want a blue shaft for?
what do you have to trade?
#5424
Main drive shaft correct? From the blue conversion kit?
#5427
Lol Izzy, my blue parts are staying in my cars until they die. Just got some Ti axles...they'll add a little rip coming off corners.
#5428
Originally posted by dsrbltoys
Duh, its part of the blue conversion kit! Tamiya part # 49335.
Oh, Get to Work. Your asting your compnay's time online! ;-P
#5429
Originally posted by tamiyarcracer
No kiddin toys, I just wanted to make sure he wanted the main shaft.
