Tamiya TB-Evolution III
#4321
Re: Re: Surikarn build.
Originally posted by JohnA
Glad you got the tip (excuse pun) before you tried to do it out of the bottle. I messed up my first chassis like that years ago!
Yeah, well I messed up the chassis a bit, but the tip about using a de-bonder worked well - guy at my shop advised acetone to remove it. Did the job :-) Apparently in water above 80 degrees C the glue becomes elastic like and can then be removed. He didn't advise this approach, as he didn't know whether the carbon deck would hold up to this!
A pic below shows how I've taken over the dining room table to build my Surikarn Excuse the Serpent box on the table
Cheers, Mark
#4322
Originally posted by rtypec
You've got a binding suspension. Loosen the screws that hold in the suspension blocks and retighten accordingly. Ideally you want no front to back movement and still keep it free. It takes a couple tries but is easy to do. Also, this is something you want to check after a hard crash
Worked perfectly - you know your stuff!
Cheers, Mark.
#4323
Originally posted by markp27
Thanks, I'll give that a go :-)
after several tried..there will be no space and moving smoothly~
#4325
Re: Re: Re: Surikarn build.
Tip-tastic, mate!
Cheers, Mark
Tip-tastic, mate!
Cheers, Mark
Enjoy your life with TB Evo III SE. Just make sure you have enough spare front 1 way gear.
Anthony
#4326
Originally posted by CIVIC91
Quick question....the brace in front of the steering, where the drive shaft goes through and it connects the chassis and the upper deck....the bearing...what holds it in place???
The front one way gear hold the spur gear. The spur gear stop the bearing movment.
Anthony
#4327
any news about the new bevel gear??? any1???
#4328
Re: Re: Re: Re: Surikarn build.
Originally posted by Anthony Yuen
Hi Mark,
Anthony
Hi Mark,
Anthony
Build day two and another picture
#4329
oops hit the wrong button Here's the pic
#4330
I ran my evo3 today with og one and had no problems what so ever with the gears, I hit thinkgs or people hit me and still nothing wrong with the gears at all>Think I got a good batch Rod the setup was really fast the only thinkg was the yellow spring felt to soft?
#4331
hey drew, trino striped like two sets of gears today!!!
he is going to try the yok's in the evoIII, so did the car pass the crutial drew test, i don't think that you got last, but are you going to stick with a car, or keep changing?
oh, and i was thinking of getting an evoIII
is there a way to stop the gear problem?(there is a gear problem, right?)
#4332
I think this is the car I wam staying with for a while, I will be at tamiya everysat for awhile The gear problem I think its just how people drive it?? I am looking at them right now and they look new no wear or anything what so ever and I drove it like I would anythign else, so to me there is no gear problem, knock on wood Ya chris you should get a evo $ 229 then come to tamiya with me and kyle.
#4333
evoIII?
or...
evoIII surkin?
or...
evoIII surkin?
#4334
Re: Re: Re: Re: Re: Surikarn build.
I'm seeing this more often Hmm, what is it that breaks? Is it the gear (the cog) or the whole unit?
#4335
Also, since you have the OG Evo3, you might look into getting the carbon fiber backing plate for the front one way gear. I don't have the part number on me but it will "help" support the front gear in some cases.
