Tamiya TB-Evolution III
#3856
R/C Tech Elite Member
Originally posted by BigDogRacing
You use a drill and sandpaper? Man that's some high falootin stuff there. Down here in Tennessee we just use an Xacto knife and whittle a little off that copper part, kinda like sharpenin ol school pencils...
#3857
Originally posted by Randman
Is that your TCS motor that's glitching Rod?
#3858
Originally posted by rtypec
Yeah I'm 99.9% sure that it's legal. Go ahead and fire up the press Marky Mark. If the power that be all of a sudden gets a hair up his wazoo that day, I'll bring you a spare upper deck from my 414M hehe.
Have you tried running this year's motor in your carbon and aluminum wonder? I've gotten severe radio problems with my two examples. I gave one of the motors to another racer for him to try out and he's got the same problems. Put in some other non-Tamiya motors and no problemo...weird I mean, it's a motor...it's not rocket science hehe.
#3859
They aren't the actual motors that I will be using at the Nats but they were test mules. Unforunately, they're both hurting. First thing to do next week is test motors and see which one will let me get around the track in one piece hehe.
#3861
Originally posted by MDawson
press is spinning already i havent tried the Tam23 yet. both of the 23s you had were off?
#3863
I donīt know of the GT7 capacitor but you can buy some really good capacitors at http://www.digikey.com/
One of the best capacitors I know of are the Panasonic FC. Very low ESR (inner resistance). Some of the speedcontrol manufacturers are using them but I think at a much higher price. Also you can buy some bigger versions @ Digikey.
Iīm using this one. Panasonic FC series 16 volt, 8200 uF.
Not very small but works very good. Digikey Part # is P10266-ND.
Downside at Digikey is a $5.00 handling charge applies to all orders less than $25.00. But maybe you could order some caps for your teammates also.
#3865
you just have to search at the right place.....
#3866
hereīs the link for the Panasonic capacitors
http://dkc3.digikey.com/pdf/T033/0687-0715.pdf
then scroll down to page 8. You should use at least 10 volt types but the 16 volt types are more save.
You can see here the dimensions also from the caps.
#3867
V12- Thanks for the link to the Caps, great stuff!
Everyone:
A while back linger measured the Tamiya and Associated springs at his work place using a materials test system. Here are the values he came up with:
Associated White 40.4 lbs/in
Associated Yellow 33.8 lbs/in
Associated Purple 31.2 lbs/in
Associated Copper 24.6 lbs/in
Associated Red 23.2 lbs/in
Associated Gold 18.8 lbs/in
Tamiya White 16.5 lbs/in
Associated and Tamiya Blue 16.3 lbs/in
Associated Silver 14.5 lbs/in
Tamiya Yellow 13.0 lbs/in
Tamiya Red 11.8 lbs/in
Associated Green 11.5 lbs/in
My question is, has any one been able to measure the newer Tamiya springs yet? Specifically:
Tamiya Super Hard (53635)
Tamiya Ultra Hard (53636)
I'd love to know their values so I can insert them into the above chart.
Thanks!
Everyone:
Thanks!
#3868
#3869
Originally posted by Sushi Boy
Anyone run their Evo 3 on carpet with foams? I am running the Surikarn with the 3mm chassis and 2 upper decks that are stacked up on each other. ANY ideas would be a great help. Thanks.
-Sushi Boy
-Sushi Boy
-Sushi Boy
#3870
Here is Martin Crisp's setup. He's a Tamiya sponsored driver, and with this setup he's car is hooked.
http://www.mpowered-racing.com/evoiiicarfoa.html
STeve
STeve
