Tamiya TB-Evolution III
#2986
Another 2 small matters ...
1. Is it normal that the spur gear (& the stuff attached to it) can move slightly forwards and backwards on the main shaft?
2. Is it normal that the steering system is free to move up and can even touch the main shaft?
Thanks, and sorry for the questions but I want to make sure I am building it the right way !
#2987
Originally posted by GTMilenko
just wondering whats the theory behind this "toothpaste trick"?
i'm sure it works but how exactly?
#2988
#2989
Yes, some movement is normal. Some have experienced a snug fit while others have a little slop.
No, make sure you install both A6 parts (plastic spacers) on top of the steering posts before you put the top deck on.
I hope this helps.
p.s. I've given up on "breaking in" my gears with toothpaste a long time ago. If you just take your time in the build/rebuild and lube the gears with whitelightning, clean/replace your bearings (blow out grease and relube with light oil if the bearings are new), your drivetrain should be free.
I hope this helps.
#2990
#2991
what extacly do you guys mean by breaking in? cuz my drive train isn't really really smooth
#2992
Originally posted by Rick Draper
RTYPEC, do you have a Surikarn edition? If not then you do not realise how critical it is to break in the gears on it with toothpaste, i built my Surikarn edition evo 3 the same as i did my normal evo 3 (that was very free when i first built it) and there was a big tight spot in the drivetrain. I then covered the front and rear gears with toothpaste and ran the car on the bench for 20 min with a old johnson 540 on 4 cells. Then i pulled the gears out of the gearbox's, cleaned them up, covered the gears in GT40 and put them back together and now the drivetrain is very free. Rick
i'm not about to try it because my driveline is super free anyhow but i'd like to know why and how it works? if you don't mind sharing, thanks
#2993
TCS EVO III asphalt setup
Hi guys!
I would like to find out what a good Evo III TCS setup for asphalt would be for the following setups
Shock Oil (front and rear)
Droop
Kick up
anti squat
wheel base
shock mounting postion top and bottom
sway bars
tires and inserts (Tamiya only tires) But any insert from any manufacture is fine
camber
caster
gearing (for a 14 turn mod)
toe in (front and rear)
ride height
roll center (camber link positions)
Thank you for responding
Droop
Kick up
anti squat
wheel base
sway bars
camber
caster
ride height
#2994
are you sure it was the toothpaste? maybe it was just the fact that you ran it in for 20mins that free'd it up? i meen what can toothpaste do? seems crazy to me. whats the theory?
-Sushi Boy
#2995
Rick, Rtypec is right. You do not need toothpaste on your gears. After running the drive train for about half a pack it won't make toothpaste or no toothpaste it will not matter. At the Reedy Race of Champions the TRF team was constantly rebuilding gear boxes and not once did they break out toothpaste.
#2996
#2997
The TRF-Team drivers are using gearboxes made from same plastic as the reinforced suspension arms. But as I have heard from teamdrivers itīs not easy making the gearboxes using this plastic so only very few gearboxes are really OK after molding. So these gearboxes will not go into production for the public. As it seems to me there is no other way than buying Square gearboxes. I just have ordered some and I hope Iīll get them this week.
Regarding gears I never heard anything different than the kit ones but maybe itīs the same as with the gearboxes.
But there is an aluminium onewaygear available in Japan/HK. Unfortunately itīs very expensive and hard to get.
#2998
I have seen some Red plastic bevel gears floating round! Rick
#2999
are the gears on the tb evo3 surikarn available in derlin? what about the crown gears?
#3000
What are some of the best electronic speed controllers on the market at the moment?
What do you think of the Novak GT7 and LRP IPC V7.1 Digital Pro Speed Control? Others?
