Bec?
Bec?
Hi, I am new to electric cars and am wondering how do I get my car to run all of its stuff off the 7.2V battery pack? Right now, the only way I can get the car to run is to hook up the 7.2 and the reciever battery pack.
BEC or Battery Elimination Curcuitry, is a feature of nearly all modern receivers. If you plug you ESC into channel 2 power is automatically provided to the receiver and the chanel 1 servo.
If you using a mechanical speed control you cant take advantage of this option unless you wire a special lead from the battery to the receiver from your 7.2V pack. If you're not using an ESC I would really recommend you get one, even a cheap one is 100 times better than the mechanical option.
I have an LRP F1 esc. When I plug the esc into the reciever, nothing happens. I have to plug a seperate battery pack into the reciever in order to power the reciever and servoes. I have a JR XR2 and I know that the reciever has this feature. Please Help
Thanks Again
Thanks Again
Hi
Don't know much about the LRP F1, but I'm sure it should be BEC compatile. May be a silly question but are your cells charged and connected correctly to the ESC? Also does the ESC work OK when U use a separtate pack for your receiver?
Yes, I can drive the car around when using two seperate packs (one for the motor and one for the reciever/servoes.
Is there some sort of special connector I need to make this work?
