amb transponder
amb transponder
is it possible to hook a transponder to a 2 chanel radio with a y connector?
thanx
thanx
were do i plug the battery or do i plug the transponder and battery into the one wlot with a y connec.?
you can use a y connector in any of the slots
the BEC or BATT slot on the RX is an input slot. The PT will not work there with most RX's. It needs to be hooked up to an output slot like a servo would. If you only have a 2ch rx, you will need a "Y" adapter.
i'm pretty sure you can use any slot
I am pretty sure too. If the Y connector is used it doesn't matter if it's input. The PT would get power before the receiver if its hooked up using a Y connector.
Tom
Tom
A PT only needs power to work, and the receiver is a convenient place to get it.
You may get some glitching if you plug it in the batt. plug, I tried it last Sat. with a fan plugged into the 3rd chan. and PT in the batt. and had glitching, swithched pulgs and solved problem.
