3 Racing Tire Truer
Originally Posted by EAMotorsports
Anyone seen one of these or had any experiece with one? I need a truer and this one seems to have some nice features and is resonably priced.
EA
EA
Does it bogg down much when going from 60mm to 54mm? I know the hudy doesnt even hardly slow down...but units like the Corally and integy almost come to a stop. Thats the main thing I was worried about.
Also will the carbide cutter from Hudy fit it?
EA
EA
you might need to retighten the screws (locite them), my arrived with screws loosen. the stock blade carrier doesn't move pass 50 or 53mm even though it's scaled to 40mm, bad for 1/12 tires. You have to use HUDY blade carrier but you will need to cut/cnc on the trapezoid base of blade carrier block. 3Racing block is about 0.8mm narrower than HUDY one.
Next you need to GLUE the sandpaper for the rounding block. The sandpaper come with the truer are self-adhesive type but it doesn't hold well, will come off after 2 to 3 roundings. I use shoe glue to glued the sandpaper to the rounding block and never worry about it since.
Other than those few tiny bugs it's worth every penny, I paid $200 for it. It uses same size DC motor as HUDY's power truer. You can adjust the auto return end points, speed of the cutter. 3Racing also includes few extra blades and sandpapers. The blades cuts good but I am using hudy carbide blades and it cuts just as nice as hudy.
Originally Posted by GrandeGixxer
The blades are hacksaw blades. Cheap to replace. I just got one, have not used it yet, but it is pretty nice. Why spend money on carbide bits that will eventually dull when you can buy a hacksaw blade for a buck and probably make 10 bits out of it?
Thanks for all the info guys. Guess I'll order me one tomorrow.
EA
If it uses hacksaw blades it is probably like my Integy in that you need to file the Hudy carbide bit to get it to fit. Not a big deal but something you should be aware of.
Hacksaw blades don't give a very good cut - the carbide bit works much better.
Josh
Josh
Carbide blade doesn't "tear" as much as saw blade. The finished cut surface with the saw blade is slightly coarse (low speed) to very coarse (high speed). The carbide the finished is similar to the tire come out of the box, very fine, smooth to lightly coarse (high speed cut). Secondly if you are taking HUGE cut carbide blade seem to cut the tire with ease and Ok finish surface, the blade had trouble getting it and very rough sufrace finish and require another pass to get a better finish. That's just my observation, I had 3racing truer since last year they might have fixes all the bugs I experienced with mine.
The hudy blade fits fine in 3racing without any problem. The only problem with the hudy blade on 3Racing is back end of the blade interfered with the riding rail when you are truing 1/8 tires or 70+mm diameter tires. You can just seat the blade 1 to 2mm higher (I believe normally you seat the blade centered to the holder).
i do not see any for sale in the US? dinball has one on ebay anyone else know where to snag one in the US? madness does not have one listed either?
Which carbide cutter is better...the Mico or the Hudy? I have been using jigsaw blades for a while with no complaints, but I'd like to try a carbide cutter.
I have one of the Mico carbide files, and it is simply awesome!
