Rubber vs Foam carpet setups?
Rubber vs Foam carpet setups? Any suggestions as to what I should change going from a foam tire to a rubber tire? I will be using a stock motor and RP24's on FT TC4. I was going to just do a rubber tire pavement setup for starters and remove the chassis stiffening.
So, blue springs, 40wt oil, 5mm ride height, more droop, 1 deg camber, higher roll centers front and rear.
Any suggestions as to toe, antidive, antisquat, more or less ackerman?
I tend to prefer a car that steers agressively with a neutral feel overall.
I tend to prefer a car that steers aggressively with a neutral feel overall.
http://users.pandora.be/elvo/ Look at the suspension page there and see section 2.6. Less droop makes the chassis dip in the corners from the droop settings. Very aggressive feel.
I really don’t have a good idea for the AE TC<whatever> for role center. Someone else will have to help you there.
I can send you my PRO4 set up if you like. Basically it is the same, however things like role center are done differently.
Snowy.
