Team Powers Radon Pro 140A ESC
Hi,
is there anybody having some problems with radon usb link 2.0 software?
I cannot update the esc firmware because when i'm in update page, labels and buttons are not in the right position in the page, so the update button results to be over other menu buttons... it cannot be pushed!
does anybody solved this?
thanks a lot
PS: what's the newest firmware ver available at the moment?
thanks a lot
Firmware
Hi,
thanks a lot
thanks a lot
I'm currently beta testing new Stock mode firmware. The low speed braking has been increased. No other changes to current 2.1 software. Personally I'll be turning the brakes down. I run very light brakes unless on a very high traction track. I'm using a V2 Pro and V2 sport in a variety of on and off road cars. I have not noticed any difference in performance. The sport can handle down to a 6.5t motor.
http://www.team-powers.com/index.php?thispage=download
Select USB link V2 and download
Now select V2.1 firmware and install.
Pm me if you have any further issues.
Can anyone help me with the setup for 1s modified? Thanks.
#20
My touring car values are probably not super far off, but this is 4.5t touring on a v2 speedo.
modified, punch a/b 3 (I run 17 in 13.5 if your motor is between these) 50%, linear, 25 boost, 15 trig lvl 3 trig rate, boost linear
turbo 10, th, instant on/off
brake 25%, 0% drag, a/b values of 10
I'd imagine you'll be higher on turbo, lower on boost, and higher a/b values having 1s.
#21
In modified, 25% brake is more than enough for me. In 13.5 I believe I run 50-62.5%. I never run drag brake, a/b values vary slightly to get a better feel on light braking down from 8 to upper value of 12
