Tekno RC SCT410.3 Thread >
Like Tree219Likes
    Hide Wikipost
Old 09-05-2022, 08:19 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno RC SCT410.3 Thread
Last edit by: rustyus
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 – V2 Adjustable Hinge Pin Brace “A” block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 – V2 Adjustable Hinge Pin Brace “C” block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B – HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 – Hinge Pins (inner, front/rear)
TKR5516 – Front Suspension Arms and TKR5515 – Rear Suspension Arms
TKR5542 – Spindle Carriers - TKR5541B Spindles
TKR6009 – Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Use steering stops/limiter washers... more info here.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Hinge Pin Insert Chart:
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Old 09-24-2017, 10:33 AM
  #5296
Trader Rating: 16 (100%+)
Thinking bout building a SCT to get my daughter racing. What kv motor would you guys recommend? Gonna be running 2s lipo and most likely will be xr8 sct pro esc.
Adim_X is offline
Old 09-24-2017, 11:11 AM
  #5297
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
start here with something in the 4000kv range an limit the EPA for throttle. My daughter uses a Tekin 4600kv 540 4 pole I got used an it works well.
The Maclan MR4 4150kv motor is an excellent option too.
Cain is offline
Old 09-24-2017, 07:12 PM
  #5298
R/C Tech Elite Member
lowspark's Avatar
Originally Posted by DirkW
Ok, Tekno experts, need a little help, please:
I didn't yet have a chance to drive it again (due to weather and work), but just dropping it down from my hand, from a height of a little more than a foot or so, the chassis did a loud, full slap on the floor. I don't suppose it's because of the pistons, since they are 8x1.4 conical, as required by the setup, with matching oil and spring... or is it? Or could it really make such a huge difference (since I don't think that setup is supposed to chassis-slap so badly) between vented and emulsion shock setup? In other words should I bother and try going back to the plastic caps, or what else could it be? Any ideas?
Go with the emulsion shocks, definitely a better choice. (use the stock plastic caps, they work fine).
And the LF springs made all the difference on my truck when I put them on. I use pink in the front and yellow in the rear.... and run 22-23 ride height on a fast track (hard packed but not smooth) ...game changer!!!
lowspark is offline
Old 10-06-2017, 08:30 AM
  #5299
I'm pretty new to Electric RC'ing. Nitro is all I know from my past racing.
I have a Tekin 4300hd in my sons SCT410 truck. The esc it came with is a no-name and not programmable without some type of extra device. I'd like a good esc but since he's 8 I don't want to spend a ton of money on it. What are some good options out there these days that are good in the $50-$75 price range(if that's even possible).
We primarily race indoor. Currently I have the throttle at 65% via the Radio but, due to the generic esc not being programmable, I can't take out any drag brake and it's making him nose dive really bad unless he stays full throttle on jumps. Thanks in advance!!
unhitchthewagon is offline
Old 10-06-2017, 09:45 AM
  #5300
Tech Legend
Cain's Avatar
Assuming new purchase, Hobbywing SCT Pro and use a glitch capacitor just in case the servo draws on the BEC hard.
https://www.amainhobbies.com/hobbywi...020262/p279090
https://www.amainhobbies.com/protek-...k-2950/p450146
My daughter ran this setup without a hiccup on her Tekno SCT410.3 before going to the XR8 SCT Pro version.
You will want a programmer, but if you like HW gear, the one will be quite useful all around.
Cain is offline
Old 10-07-2017, 11:31 AM
  #5301
Backyard RC's Avatar
Here's a couple shots of my dirty Joker after Thursday's muddy race. This summer has been my first race season and I really had a good time with my Tekno. It held up beautifully.
Backyard RC is offline
Old 10-10-2017, 12:25 PM
  #5302
Default LF Springs
I run almost exclusively on carpet. Would it be wise to transition to low frequency springs? If so, which ones?
Tibbar110 is offline
Old 10-10-2017, 12:45 PM
  #5303
Yes, I like the orange/green on turf. run 20mm ride height.
ezlight is offline
Old 10-10-2017, 01:09 PM
  #5304
I need more info. Which one in the front and which in the rear? Are you using traditional or LF springs?
Old 10-10-2017, 01:13 PM
  #5305
Trader Rating: 22 (100%+)
top of the page...see the Wiki post
ezlight likes this.
Bob Barry is offline
Old 10-10-2017, 05:20 PM
  #5306
Why is the Team setup so stiff on the front? Orange springs?
Is that for a smooth track with high traction?
What about rough as hell but pretty good traction
Malazan is offline
Old 10-13-2017, 04:44 PM
  #5307
Default TKR8100 .4 ackerman
Can anyone tell me which direction the optional ackerman goes? Offset forward or backward?
sokaok is offline
Old 10-18-2017, 12:41 PM
  #5308
Shock talk. I see online parts say they work for the EB48 and SCT. I'm new to Tekno and learning what works with what. Is that correct that the Shocks from the EB48 are the same as what comes with the SCT410.3?
Springs - what's the difference in regular springs and the new LF springs?
Thanks!
Old 10-18-2017, 02:56 PM
  #5309
Trader Rating: 35 (97%+)
Thanks!
The front shocks of the eb48.3 and .4 are the same as the rear shocks in the SCT410.3.
The front shocks in the SCT are the same as for the SL and the earlier eb48s (.1 and .2).
LF springs seam better suited for rougher tracks, thats my take.
Tbuggy is offline
Old 10-21-2017, 04:46 AM
  #5310
BigBoss0311's Avatar
Hello to all! New to R/C, but after reading several threads here I have learned quite a bit. I love the SCT look and want to stick with that. After seeeing many threads on this subject, I feel the 410.3 kit is a good base for my build. I have chosen a few products to help finish the build and would like input from those in the know. I want quality and am willing to pay for it, but don't need super high-end. No real racing in the future, just want quality parts that will last and give good results. Here is what I am looking at so far:
Hobbywing Motor/ESC Combo-183.99 (XR8 SCT Pro ESC and XERUN 3660SD-3600kv)
ProTek RC 150T Digital High Torque Metal Gear Servo-119.99
Spektrum RC DX2E Active 2ch DSMR Radio-59.99
AKA 12mm wheel/tire combo
Please let me know if I should be looking at something else, what else I will need to get this thing up and running, or if there are compatibilty issues. I am also okay with spending less if the performance is there. Thanks!
ezlight likes this.
BigBoss0311 is offline
