Tekno RC SCT410.3 Thread >
Like Tree219Likes
    Hide Wikipost
Old 09-05-2022, 08:19 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno RC SCT410.3 Thread
Last edit by: rustyus
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 – V2 Adjustable Hinge Pin Brace “A” block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 – V2 Adjustable Hinge Pin Brace “C” block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B – HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 – Hinge Pins (inner, front/rear)
TKR5516 – Front Suspension Arms and TKR5515 – Rear Suspension Arms
TKR5542 – Spindle Carriers - TKR5541B Spindles
TKR6009 – Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Use steering stops/limiter washers... more info here.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Hinge Pin Insert Chart:
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Old 07-26-2017, 12:35 PM
  #5146
Trader Rating: 22 (100%+)
Originally Posted by gawith0413
Are the part numbers for these listed on the setup sheet?
Yes, but I added them to the Wiki just now.
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8100 .4 ackerman
TKR5545B HRC Hubs
Bob Barry is offline
Old 07-26-2017, 01:18 PM
  #5147
teknotank's Avatar
Evening (afternoon for you guys) Nick here from the UK , just registered.
You don't realize how lucky you guys are over in the US with all your short course tracks!
We don't really have any specific SC tracks over here, I have to run mine on 8th outdoor astro which is really pushing it's capabilities !
Only been built a few weeks but it's had some hard use already. What a truck, absolutely love it !
Still playing with setup's but it's getting there.
Nothing fancy in mine;
-Tenshock 4400kv
-Hobbywing WP SC8
-Power HD 20kg MG
-Proline F11 / DE borrego
-Schumacher mini pin's
-J concept Raptor shell (Proline Flo tek lasted 5 meets!)
-Turnigy nanotech / Graphene 2s
-Tekno ali servo horn
-Tekno Low freq springs (Pink Front / Yellow rear)
- 15t Pinion
Diff's i'm running 7 - 10 - 3 (need to change to 5k rear)
Front shocks;
- 450cst
- Pink low freq springs
- Droop 103mm
- Ride height 21mm
Rear shocks;
- 350cst
- Yellow low freq springs
- Droop 114mm
- Ride height 20mm
Can't post any photo's as I've not made enough posts!
teknotank is offline
Old 07-26-2017, 04:54 PM
  #5148
gawith0413's Avatar
Trader Rating: 86 (100%+)
TKR8100 .4 ackerman
TKR5545B HRC Hubs
Thanks man!
gawith0413 is offline
Old 07-26-2017, 05:23 PM
  #5149
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
am I right if you find someone parting out an EB48.4 you can just grab the belcranks and ackerman from it, but you dont' want the turnbuckles that would connect to the belcranks?
are the diff oils for the recommended setup PT Racing oil brand? If so, from what I recall AE brand need to go slightly softer right? Thinking 10-10-5 here using AE. Right now at 15-15-5.
Cain is offline
Old 07-26-2017, 05:28 PM
  #5150
I find PT oils to be slightly thinner. So 15-15-10 would be like 13-13-8. I'm just estimating. No facts. Just a feel thing.
Old 07-26-2017, 06:01 PM
  #5151
Tech Legend
Cain's Avatar
thanks was thinking the same thing.
Cain is offline
Old 07-26-2017, 08:16 PM
  #5152
gawith0413's Avatar
Why is part number TKR8027 needed for the setup?
Old 07-26-2017, 08:42 PM
  #5153
That setup also calls for the aluminum suspension hangers, like the ones on the EB48.3 instead of the included composite ones...
blankenj99 is offline
Old 07-27-2017, 04:12 AM
  #5154
Trader Rating: 11 (100%+)
You do need the aluminum C block to match that setup, but the rest can still be composite.
anr211 is offline
Old 07-27-2017, 06:01 AM
  #5155
Oh I didn't realize there was a difference. I've never used the plastic A,B,C,D blocks. My apologies.
Old 07-27-2017, 06:34 AM
  #5156
When you run the aluminum emulsion caps, this stand off gives you a little more clearance from the shock tower. I've never tried the plastic caps so I can't say if you still need that extra clearance or not.
All in all, if you put on all of those parts and freshen up any worn parts on your truck (if needed of course), you essentially have an SCT410.3.5. Not quite a .4, but way more than a .3. This was my experience with the EB48.3 too.
If you are a serious SCT racer and race this truck, IMO these option parts are all must haves. If you aren't, then clearly you may not get the value out of them. Only you can make that call
Old 07-27-2017, 10:21 AM
  #5157
The truck comes out of the box with plastic shock caps and work just fine with the included stand offs. The only difference is if you go to emulsion on the truck with the plastic caps is how the cap itself is prepared.
ezlight likes this.
anr211 is offline
Old 07-27-2017, 10:55 AM
  #5158
Correct, but if you initially prepped those shock caps as vented, you'll need new, with all the o-rings. Might be the cheaper way to go, but I haven't compared myself yet.
ezlight is offline
Old 07-28-2017, 10:41 AM
  #5159
The stand offs are for the aluminum emulsion caps. They are not the same as the plastic. And personally I won't run plastic caps on anything that's bigger than a 10th scale buggy. It's a personal preference, so please, do as you feel is best for you.
Old 07-30-2017, 08:38 PM
  #5160
gawith0413's Avatar
as mentioned the parts are listed on the sheet, but here's the quick list...
Emulsion caps
Shock stand offs for emulsion caps
.4 ackerman
.4 bell cranks
new steering turnbuckles (or just cut 3mm off each end of stock ones. That's what I did)
LF springs (I think it was Orange and Yellow Front, Green Rear)
HRC rear Hubs
Once you do these things, you'll have a totally new truck. It's crazy how much these change it.
So 50mm turnbuckles are needed for the steering?
