Power Supply/GFX Question
Yes, this will be fine. With nothing else attached to the powersupply, as long as you don't charge batteries at higher than 15 amps, you'll be fine.
Make sure you check the specs. I can't remember if it needed a 15amp or 20amp minimum.
Trader Rating: 51 (100%+)
tc3blue I think you may need a 23a power supply and up you may want to contact Competition Electronics anything smaller than that might not work
http://www.competitionelectronics.com/
Check the input voltage when you connect it to GFX at DATA Mode. If the numbers are quite stable, then you are good to go.
