New Schumacher KF2 >
New Schumacher KF2
Like Tree12Likes
New Schumacher KF2
    Hide Wikipost
Old 07-29-2016, 08:27 AM   -   Wikipost
R/C Tech ForumsThread Wiki: New Schumacher KF2
Last edit by: MelKF2
Welcome to the KF2 Wiki!
Please feel free to add any Tips, Tricks, or anything that would be beneficial to the KF2 Family
Introduction and Pictures Introduction and Pictures
ElectronicsSetupElectronicsSetups
Setup SheetsSetup Sheets
EmulsionShocksEmulsion Shocks
Tony Newland Gear Diff BuildTony Newland Gear Diff Build
Suggested Gearing
6.5
7.5
8.5
9.5
10.5
13.5
17.5 I ran 69/31 at SRS Scottsdale Arizona and 72/30 at MHOR Aurora Co and Full Throttle ALB, NM RCM lockout worked excellent!
MIP pucks excellent upgrade! The new RCM lockout is an excellent piece as well! These options will greatly reduce weight throughout the drive line!
Print Wikipost
Old 03-06-2016, 08:32 PM
  #751
Trader Rating: 22 (100%+)
Ran my car on a high bite carpet track on Sat, then medium grip clay on Sun. 17.5 motor in both. I was running in stock and mod and able to run the same setup changing only tires. This car is awesome.
Bob Barry is offline
Old 03-11-2016, 08:13 AM
  #752
Hey have any of you guys tried running the Mid Motor config with no top deck and the Alum chassis? I was tempted but not sure if it will be too much flex. I know guys ran the low grip position with no top deck or side stiffeners, but that still had the rear deck.
I have an old KF Carbon chassis that i need to drill out and try.
Old 03-11-2016, 02:30 PM
  #753
oldernoob's Avatar
That's the layout I intend to try (alloy,MM and no top stiffener)
oldernoob is offline
Old 03-13-2016, 11:13 AM
  #754
the big rc's Avatar
Trader Rating: 40 (100%+)
does anyone make a slipper eliminator for this car?
the big rc is offline
Old 03-13-2016, 11:16 AM
  #755
303slowdown's Avatar
Trader Rating: 24 (100%+)
Rc madness does, its a 3d printed one, you can usually find them on ebay. Type in kf2 lockout.
303slowdown is offline
Old 03-13-2016, 03:43 PM
  #756
Mopar's Avatar
Well, last night was not what I was hoping for. We had twice as many in class, but still landed in 6th of the A main on the grid. In the warm-up lap, yes just 1 lap, I got hit or took a weird hit and broke the aluminum rear upper camber link mount. Seems it's not machined like it appears to be, but a cast part. Oh well, no three peat this week.
Mopar is offline
Old 03-13-2016, 03:45 PM
  #757
Mopar's Avatar
This is my slipper eliminator. Just the outside plate, Jcon spur, the holes match perfect, and 15mm of a carbon arrow shaft as a spacer. 2 ASC suspension pin retaining screws complete. Hope this helps. If you're not into archery like me, see a local bow shop.
https://www.facebook.com/84085685269...457636/?type=3
Schumacher KF2 SE Nation's photo.
Mopar is offline
Old 03-14-2016, 09:44 AM
  #758
the big rc's Avatar
Got it ordered, thanks!
Kevin
Old 03-14-2016, 05:45 PM
  #759
I had a very similar break on the same part. I came off a jump, landed just a bit sideways and the part broke. I notice that mine was a cast part as well.
Riverbluff is offline
Old 03-18-2016, 06:00 PM
  #760
Mopar's Avatar
It seems they use a form of DMLS, or 3D powder metal printing for these parts. At least that's what a friend said who is a engineering major.
Mopar is offline
Old 03-19-2016, 08:18 AM
  #761
Default Alloy rear camber mount
I have this option in my parts box! Have never used it because Vision Racing has a carbon rear brace that has all three options on one dink! I was worried about strength due to all the holes on one piece however, for the past 3 months with some bad crashes still going strong! Well worth the $15.00 (DRC).
MelKF2 is offline
Old 03-22-2016, 04:09 PM
  #762
the big rc's Avatar
This thing blows and doesn't fit at all. going to try the other one that was posted.
Old 03-22-2016, 04:15 PM
  #763
I just used the 2 disc method. Remove the basket, use a B5 slipper spring and clamp it. It worked ok and still gave me cushion when I landed hard on the throttle.
Old 03-22-2016, 04:16 PM
  #764
What are you guys using for chassis protectors? I just ordered some from the UK today but shipping and conversion rates kill me. Would love to find something in the US.
Old 03-22-2016, 04:40 PM
  #765
the big rc's Avatar
I've decided if that rotating mass is the difference between winning or not, so be it. Time to go back to mod anyway
