New Schumacher KF2 >
New Schumacher KF2
Like Tree12Likes
New Schumacher KF2
    Hide Wikipost
Old 07-29-2016, 08:27 AM   -   Wikipost
R/C Tech ForumsThread Wiki: New Schumacher KF2
Last edit by: MelKF2
Welcome to the KF2 Wiki!
Please feel free to add any Tips, Tricks, or anything that would be beneficial to the KF2 Family
Introduction and Pictures Introduction and Pictures
ElectronicsSetupElectronicsSetups
Setup SheetsSetup Sheets
EmulsionShocksEmulsion Shocks
Tony Newland Gear Diff BuildTony Newland Gear Diff Build
Suggested Gearing
6.5
7.5
8.5
9.5
10.5
13.5
17.5 I ran 69/31 at SRS Scottsdale Arizona and 72/30 at MHOR Aurora Co and Full Throttle ALB, NM RCM lockout worked excellent!
MIP pucks excellent upgrade! The new RCM lockout is an excellent piece as well! These options will greatly reduce weight throughout the drive line!
Print Wikipost
Old 04-11-2015, 10:35 PM
  #196
Originally Posted by Tony Newland
They run both chassis'
The carbon is about a 60g weight savings... but either way theyre not running the front stiffeners, side dams of battery holdowns... servo tape the battery in and I think theyre weighing in around 1510-1550g
Just did all the above and also eliminated 2 pads and 2 discs in the slipper clutch (I used a longer slipper spring from a B44.2) and saved 13.4 grams of rotating mass. Race ready my car weights in at 1515.1
NWracer77 is offline
Old 04-11-2015, 10:45 PM
  #197
Tony Newland's Avatar
Trader Rating: 53 (100%+)
Ya forgot to mention that about the slipper... some of the guys have made slipper eliminators for stock
Tony Newland is offline
Old 04-11-2015, 10:56 PM
  #198
Have a friend working on a short Ti layshaft for me...also gonna mill down the basket that holds the slipper assembly to fit the reduced number of pads/discs
Old 04-11-2015, 10:58 PM
  #199
I run a chunky 210g shorty as well...I can def get her under the 1500 without too much issue.
Old 04-11-2015, 11:13 PM
  #200
By the time that's all said and done it should be damn near 21+ grams of weight out of the drivetrain...pretty significant savings
Old 04-12-2015, 06:42 AM
  #201
Any part numbers on what I need to flip my rear shocks to the rearward mounting position? Can't seem to find anything and the stock shock mounting posts are too short
Old 04-12-2015, 07:06 AM
  #202
motorcitymatt's Avatar
All you need is U4616. DiscountRCstore.com usually has them but I think they are backordered.
And keep us posted on those Ti layshafts. I would be interested.
motorcitymatt is offline
Old 04-12-2015, 07:32 AM
  #203
Jpdanger's Avatar
I grew impatient waiting for u4616 to be restocked, so I made my own. I purchased u4615 from amain and carefully cut the top off rear upper tranny half u4189.
Attached Thumbnails New Schumacher KF2-10356772_10153219446638980_7262966684257421126_n.jpg
Jpdanger is offline
Old 04-12-2015, 07:34 AM
  #204
Jpdanger's Avatar
Do you have any info on making a slipper eliminator?
Jpdanger is offline
Old 04-12-2015, 07:58 AM
  #205
I think theyre using a piece of aluminum tubing and locking the nut down
Old 04-12-2015, 08:00 AM
  #206
Here's my setup with the B44.2 slipper spring....almost a half ounce savings in weight. 13.4 grams on the scale
Old 04-12-2015, 08:33 AM
  #207
May also see if my friend will help me make a direct drive for it...I'm thinking a short shaft, drill a couple holes in the back plate, screw the spur directly to it...you would also be able to use lighter weight spurs...don't know how it would affect overall drivetrain durability but in stock class it should hold up
Old 04-12-2015, 02:16 PM
  #208
Trader Rating: 14 (100%+)
I put together my KF2 kit last night and was just wondering if anyone else had a hard time getting the rear pins that hold the arms on with those little ball ends that slip into the suspension mounts and the rear suspension strap?
I had to really press it together with some force... I would hate to have to change a rear arm out :/
I hope I didn't bend any of the mounts/pins... I could feel the chassis (CF) flex a bit while trying to press the whole assembly together.
Sam
sstriano is offline
Old 04-12-2015, 02:26 PM
  #209
A couple other questions for you guys:
1) Those 1MM Quick-Clips are junk, they fall right off, should I just put a 1MM shim in place of them?
2) I am running the alum. rear link mount, and I was told to run 3MM spacers under it between where it mounts. The ball studs are now higher than the stock CF piece running 3MM spacers under the studs. Is this right?
3) I am using the Core-RC servo arm, and it is like a hair from or maybe even rubbing a tad on the top of the bulk head? I have dropped the servo all the way down towards the chassis. Savox 1258T. Has anyone else seen this?
4) How much black grease should I put on the transmission gears? I put a little blob on and then ran it through the gears, seems like enough?
5) How tight do you run the belt? I have heard and seen a whole different slew of thoughts on this.
Thanks!
sstriano is offline
Old 04-12-2015, 08:16 PM
  #210
Sam
I basically had the same experience when I did the assembly. It was definitely a tight fit. I think I had to gently tap the back aluminum hinge pin block with a plastic mallet to get everything to seat right. After about 8-10 packs I pulled the whole rear end apart and those parts had freed up to the point where it was much easier to reassemble. But not to the point of slop or play.
Just make sure the suspension moves freely without binding before you put the shocks on. I am betting you didn't hurt anything.
