RSD RR12 12th Scale Pan Car Kit
#351
Aluminum Chassis
I've been out of 1/12/ for quite some time but what is the benefit of the aluminum chassis? Is it more from cg standpoint or flexibility?
#353
#355
Cristian, I assume you'll give us a heads up here when the alloy chassis are available to order?
#357
Yes, I will post up when they become available. I am shooting for late next week.
On the chassis, I don't know what to tell you Edward. That is the normal train of thought for sedan, but I actually tested the Alloy chassis first on a new track layout, so the bite was low. The car seemed to generate a little more grip, and I think this was due to the fact that a further forward weight bias is created by the allow chassis. I think this is transferring more weight to the rear tires under acceleration. Either way, the chassis was super composed and never felt less hooked up than a carbon car.
#358
Seen the car run up close last weekend. I honestly don't know how much of a difference the aluminum chassis made over the carbon one cause I only saw the aluminum one run. What I can tell you, though, is that the car ran very very well. Went into the corners flat, never looked upset. Plus I think that the front end on that car is a huge step above standard associated front end.
Martin Paradis
Martin Paradis
#359
Martin Paradis
Martin Paradis
#360
Martin
