Yokomo YZ-4
#901
hi john, I've moved to Oroville and been running at amains outback track.... super hooked clay pretty much everyone running primes but still miss running at lrh. I limit up travel to keep the dogbones from hitting the outdrives. i'm using the plastic shock towers and flat front arms, mostly stock with the roll bars and narrow rear belt. I've only had the car a week or so still trying different stuff but for me I need more pack in the rear how they get 1.7 to work I dunno
#904
Normally leave the battery in the car. Drive another car while one is on the charger.
#905
I would call amain and ask them. the more people that call and ask the more likely they will order them. I think there's 4 different rear arms that can fit, yz2 arms, s4, bmax4, and L5. I got a yz2 front bumper to fit on my yz4 by making a notch in the rear of the front hanger.... so much nicer when the front bottoms out it hits the back edge of the bumper instead of the back of the arms and hanger
#906
#907
graphite front arm flat +1mm z4-008f1
rear arm +1mm z4-008rl5
rear suspension mount front side for l5 arm z4-300lrf
rear suspension mount rear side for l5 arm z4-300lrr
aluminum rear suspension mount spacer (front side) z4-300rfs
aluminum rear suspension mount spacer (rear side) z4-300rrs
aluminum narrow pulley z4-630
aluminum pulley flange outside z4-630f3 inside z4-630fc
aluminum main shaft z4-644h
rear hard stabilizer set b4-412rh
5mm rear wheel hub b4-011r
these are some of the parts available from mibo but not amain
#909
You may also want to check out Berzerk RC from Australia. They have two to deck designs and will ship to the States. I'd also suggest picking up their YZ-4 lipo mounts. Got two decks and lipo mounts shipped to the States for not much. Shipping was $10 AUD which is about $7 USD.
#911
I'll look into the other parts. Thanks for the list.
