Yokomo YZ-2
#1321
I'm having trouble getting my steering setup to get full throw both directions..... I can make it lockout to the left, but still 2-3mm from locking to the right. I've tried shortening the arm, lengthening the arm, offsetting the servo horn, I just can't get it. Is it not supposed to go lock to lock ?
#1322
All cars can go lock to lock on the steering and over throw in some. If not check your servo. Obvious is that when you over throw set the E.P.A. (end point adjustment) down, or not enough throw, set it up. Length of horn will give actual more steering response over short, but same throw. Length of steering rod will help adjust centering of wheels, to offset of horn, in some cases readjusting of horn and rod is necessary to adjust for full throw in one direction.
#1323
I always adjust my EPA to full throw or lock to lock on all cars. Then I adjust my Dual rate for conditions 100% being max steering, mostly I run the yz2 about 75-85% steering.
#1324
Then trim sub then to the right then put the horn on angle to the left a little.
Then epa on my futaba radio to get full throw on both sides. It will not be even on your epa steering
#1326
The Y-max has been .2 a lap faster then my best Bmax2 setup.
#1328
I think this was Yokomo B-MAX2 MR V3 1/10 2WD Competition Electric Buggy Kit [YOKB-MAX2MRV3]
was $159 last week.
maybe something for us to think about getting..
http://factory-rc.com/ kit is $54.95 plus the parts you need for $86
you at $140+
Is the Yokomo B-MAX2 MR V3 the right kit to have to make it Y-max?
#1329
Mr. Pike
was $159 last week.
you at $140+
was $159 last week.
you at $140+
I'd by the Yz2 and get the Bmax kit ONLY if I was also running the 4wd buggy. Reason I say this is because the spare shock, parts,etc.
You'd also end up with a spare gear diff which is nice when testing fluids.
However if I was on a tighter budget and or NOT running the 4wd car I'd get a Yz2, the $86 parts and conversion. This allows you to go back and forth without wasting any parts or $$.
I can convert back and forth in about 20 minutes between the two if I have to. I think anywhere the B5m's are able to put power down where the Yz2 struggles the Y-max conversion is the answer.
#1330
Thanks sir. Missing the 1x B2-118MR Waterfall support mount from amain.
#1332
then Factory rc kit
Supertruck1 thanx sir.
Still thinking about the change. sir.
#1333
You don't need the rear T plate that's for the bmax chassi. You do need the pils or the black inserts for the rear blue front suspension mount.
#1335
So do I need the
B4-008R1
http://www.mibosport.com/rear-lower-...arm-1mm-longer
or
B4-008R
http://www.mibosport.com/rear-lower-suspension-arm
and the shaft
B2-010RB
or this
B2-010R
B4-008R1
or
B4-008R
and the shaft
B2-010RB
or this
B2-010R
