Yokomo YZ-2
#1021
With the car having taken about a 50% market share at one of my local tracks, I was asked by several guys for my setup so I told them to look for it here as I've reached a high enough degree of confidence in it now to share it.
Indoor carpet; Ozite/"Regular" carpet mix; wood jumps, some well constructed, others
Car weighed 1503g as it hit the track.
As a side note, since I know the guy who makes the editable sheets comes through here, please consider adding a check box for front arm/tower type instead of having to put that in the notes section.
#1022
I'll have a look at the tower/arm option.
knowing more options are coming, its gonna be quite a challenge putting every thing on that single sheet of paper.
#1024
Im back at it tomorrow night, and ive left the set up as it was, hoping itll be quick from the get go.
100% id go 4mm ackerman spacers, way more predictable and you can attack the corners without a skittish entry, at least, thats how it felt for me.
I still cant get my head around a geared diff though, ball diff every time!
lee
#1026
Build was going amazing til I noticed they didn't mill the rest of the top shaft! Just a cylinder at the end. Amain's customer service closed at the exact same time I realized this was a factory mistake, now I've got to wait til Monday to get this resolved. Tried to post a picture but I dont have a high enough post count yet so oh well. First world problems eh
Anyone else get one of these or am I just a lucky guy?
Edit: Pic up on my profile
#1028
#1029
Your question has a stamp of approval by all and most have put their set ups out their already. So yes get one!
#1031
1. Question to pills? The graph shows, for D block pills, top part is angle of hinge pin in degrees. Right side of chart is toe angle. This changes angle of back of pin. Pills for C block arrow up is pro squat, arrow down is anti squat. This changes angle of front side of pin up or down.
2. Question to rubber sheet? It's used for tuning, it does raise and lower parts they are under, similar to roll center.
#1033
Losi was doing similar thing with old 22.
#1034
I've run my yok for two club races now and I'm getting slower... Started with Synlist neutral setup and made small changes trying to be smoother. I run a med size track 60ft straight, with tight lanes. It's dirt, with wet to dry and gets dusty rather quickly for I'm in the dessert. Running 27r/30f oil and kyosho whites f/r. Added 3mm on rear hubs, 1deg camber f/r. Battery full back, and running same tires as the fast guys. I have added the yok 25gram weights and now thinking of adding more under the gear. Any suggestions would be great as I'm alone in a sea of B5m's.
#1035
