Like Tree485Likes
Yokomo YZ-2
    Hide Wikipost
Old 11-11-2021, 01:35 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2
Last edit by: lexusbest
Welcome to the YZ2 Wiki!
Features for the lastest specification YZ-2DTM3.1
  • Long specification for dirt Main chassis Inheriting the chassis cut of dirt specification, it is longer with the same wheelbase as CAL3.
  • Aluminum front suspension mount.
  • Z2-DTM2B F2 body.
  • JConcepts ASTRO High Clearance 7inch Wing.
Features for the lastest specification YZ-2CAL3.1
  • Long specification main chassis for carpets. Long wheelbase that enables even higher speeds.
  • Steel front suspension mount.
  • Z2-DTMBL S2 Lightweight body.
  • Z2-CAL2W LMR Wing.
Common features for the lastest specification YZ-2DTM3.1 / YZ-2CAL3.1
  • The conventional position and the position of the suspension arm pin 1 mm higher can be selected on the front and back of the front suspension mount.
  • Bulkhead integrated side plate with increased rigidity.
  • The kingpin position has been changed with the new steering hub carrier, the axle position has been lengthened by 1 mm, and a steering stopper has also been added.
  • Battery holder that is easy to adjust according to the height of the battery.
  • Separate the rear mount base and upper arm holder to increase the flex around the rear and improve traction.
  • Z2-018-5 5-hole shock mounting specification Rear shock tower.
  • S4-S1S 3.0mm shaft specification front shock.
  • S4-S1M 3.0mm shaft specification rear short shock.
  • S4-008R5B L5 / LD Rear suspension arm (Φ3.5 pin).
  • Z2-01069 Rear universal shaft (69mm bone).
Setup Sheets can be found here
DT CA DTM parts comparison
YZ2T Tranny Conversion List
YOKZ2-300RFT
YOKZ2-302CT
YOKZ2-302T
YOKZ2-304T
YOKZ2-503I
YOKZ2-0023
CAL3 manual
DTM3 manual
Print Wikipost
Old 10-18-2015, 03:07 PM
  #1546
BigPinion's Avatar
Trader Rating: 21 (100%+)
Has anyone experienced the rear arms splitting on the molding seem on the inner hinge pin side? I've had three do the same thing from what are very minor contacts or tumbles. I run on high grip astroturf and I am thinking there may have been a bad production run on these arms. They don't break completely they are just cracking.
I have 2 YZ -2'S and it's happened on both cars.
BigPinion is offline
Old 10-18-2015, 04:35 PM
  #1547
Yup, splits right across the mould seam.
Always been from a direct hit to the side of the wheel, not necessarily a hard hit but a hit non the less.
Both the yz2 & bmax4 arms split across it.
Mi4cxl is offline
Old 10-18-2015, 05:09 PM
  #1548
BigPinion's Avatar
Always been from a direct hit to the of the wheel, not necessarily a hard hit but a hit non the less.
Glad I'm not the only one... I can handle a couple split rear arms for how awesome the car is on the track. Yokomo spares don't break the bank either.
Old 10-19-2015, 06:57 AM
  #1549
On my first day of running the yz2 i also split a rear arm as you describe. Also heard this problem from a friend.
Hope a new revision will be out to fix this
daniz is offline
Old 10-19-2015, 07:10 AM
  #1550
I got the same issue and broke three arms at the same location, was using Bmax4 III arms, a little weaker than stock arms.
In fact my hinge pin was bent a little and that was why I broke those arms, check yours, found that bent pin was the issue.
mojo tom is offline
Old 10-19-2015, 07:47 AM
  #1551
mes
Never had this happen on either the stock or the B-Max4 III arms. I am still on the first set of each, and my driving is average at best.
mes is offline
Old 10-19-2015, 03:12 PM
  #1552
Trader Rating: 357 (100%+)
Had buggy from day 1 when it hit Amain. Never broke an arm.
jmoneym is offline
Old 10-19-2015, 04:02 PM
  #1553
Joel Lagace's Avatar
can u post a picture of the plit?
Joel Lagace is offline
Old 10-20-2015, 01:03 PM
  #1554
the incubus's Avatar
Trader Rating: 17 (100%+)
Hey Gents, Finally took the plunge and bought 2 YZ-2's. One for myself and one either for Wifey or my son to replace his PRS1 MM which has been excellent. We run outdoors on dirt/clay mix with really good grip thanks to the calcium they drop the night before we race.
I realize this thing is a tad light in the rear but I aim to remedy that with some of my homemade ingenuity to add a touch weight as low and as far back as possible. If my idea does as well as I expect, this thing will be beast with the original lay down tranny. Either way I think it's going to be fun!
the incubus is offline
Old 10-21-2015, 06:15 PM
  #1555
Congrats on your new YZ's. I have found that if your setup is dialed and you have the right tires, this thing can work very well on medium bite surfaces.
afm223 is offline
Old 10-21-2015, 09:30 PM
  #1556
Trader Rating: 166 (100%+)
And holding forward momentum, if you go those things mentioned above, and keep your momentum going, car is awesome.
jpcopeland1 is offline
Old 10-21-2015, 10:06 PM
  #1557
Thanks for the tips gentlemen. I just thought of something we used to have back in the day from Team Hammer… A Bi-Level Off-Road wing where the upper pane was adjustable.
This would add more downforce over the rear of the car without literally "weighing" it down. Might have to finally get going on my Wing design. Always making more work for myself.
Grrr! LOL
Old 10-22-2015, 07:18 AM
  #1558
Grrr! LOL
Back in the 80's. Their was a wing that had tie rods attached to the rear arms. When car was jumping allowed the wing to move forward. And when going down the straights allowed it to move back. I forgot who made the wing? The adjustable bi wing rattled the old memory.
jake alton is offline
Old 10-22-2015, 07:31 PM
  #1559
avaldes's Avatar
Are there any body options for the YZ-2? I see the stock/lite and the Azarashi...anything else available?
avaldes is offline
Old 10-22-2015, 07:58 PM
  #1560
I think those are the only ones available right now. I just painted up a Yokomo light version today. It is very thin.
afm223 is offline
