Like Tree485Likes
Yokomo YZ-2
    Hide Wikipost
Old 11-11-2021, 01:35 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2
Last edit by: lexusbest
Welcome to the YZ2 Wiki!
Features for the lastest specification YZ-2DTM3.1
  • Long specification for dirt Main chassis Inheriting the chassis cut of dirt specification, it is longer with the same wheelbase as CAL3.
  • Aluminum front suspension mount.
  • Z2-DTM2B F2 body.
  • JConcepts ASTRO High Clearance 7inch Wing.
Features for the lastest specification YZ-2CAL3.1
  • Long specification main chassis for carpets. Long wheelbase that enables even higher speeds.
  • Steel front suspension mount.
  • Z2-DTMBL S2 Lightweight body.
  • Z2-CAL2W LMR Wing.
Common features for the lastest specification YZ-2DTM3.1 / YZ-2CAL3.1
  • The conventional position and the position of the suspension arm pin 1 mm higher can be selected on the front and back of the front suspension mount.
  • Bulkhead integrated side plate with increased rigidity.
  • The kingpin position has been changed with the new steering hub carrier, the axle position has been lengthened by 1 mm, and a steering stopper has also been added.
  • Battery holder that is easy to adjust according to the height of the battery.
  • Separate the rear mount base and upper arm holder to increase the flex around the rear and improve traction.
  • Z2-018-5 5-hole shock mounting specification Rear shock tower.
  • S4-S1S 3.0mm shaft specification front shock.
  • S4-S1M 3.0mm shaft specification rear short shock.
  • S4-008R5B L5 / LD Rear suspension arm (Φ3.5 pin).
  • Z2-01069 Rear universal shaft (69mm bone).
Setup Sheets can be found here
DT CA DTM parts comparison
YZ2T Tranny Conversion List
YOKZ2-300RFT
YOKZ2-302CT
YOKZ2-302T
YOKZ2-304T
YOKZ2-503I
YOKZ2-0023
CAL3 manual
DTM3 manual
Print Wikipost
Old 01-15-2015, 02:43 PM
  #136
p
mhuse6969 is offline
Old 01-15-2015, 02:44 PM
  #137
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
Originally Posted by mhuse6969
I got hella pics but cant seem to upload them. Think they are too high quality. Anyone have any ideas. Just finished build...
Or you can use photobucket or something like that to publish them
Ultraspeed84 is offline
Old 01-15-2015, 02:50 PM
  #138
Suspended
Trader Rating: 61 (100%+)
upload to imgur.com
copy and paste "BB code" to imbed here.
Socket is offline
Old 01-15-2015, 02:51 PM
  #139
Ill try again later, but the process to post pics to this old site is painful.
Old 01-15-2015, 02:52 PM
  #140
Ill try again later, but the process to post pics to this old site is painful. Or check my fb page. Michael Huse
  #141
does the kit come with 2 , 3 ,or 4 hole pistons? and whats diff fluid do they supply?
Old 01-15-2015, 02:57 PM
  #142
The pistons it comes with are not the best quality. I am going to use machined pistons. 3000wt for gear diff.
Old 01-15-2015, 03:04 PM
  #143
Old 01-15-2015, 03:12 PM
  #144
Suspended
upload to imgur.com
Socket is offline
Old 01-15-2015, 03:55 PM
  #145
neallewis's Avatar
Originally Posted by MOmo
So is MB carrying the parts already? The US importer, AMAIN only lists the car, but the parts support doesn't reflect in the system.
I want to order one, but the fear of driving it before parts are available is a bit scary. Would hate to wreck it on the first outing, and be waiting 6wks for spares to be available.
I COULD order from overseas, but cost wise, does it average out esp where shipping and cost are concerned?
Really looking fwd to getting one. A few people here have ordered them.
MOmo
MB had everything needed on the day the kits arrived: http://www.rccarshop.co.uk/index.php...html?limit=480
Can you order from MB or Yokomo.eu/mibosport? Actually I don't think MB ship stateside currently?
Some parts like new chassis and some alloy parts in kit, etc are not in stock now, but will follow. Parts support is most important thing. I spent about 50% of kit price on spares and options/extras like the range of springs, 30deg bulkhead, gullwing front tower, new ball diff, chassis weight, etc.
Just wiring mine now. its a bit tight. Hoping to run it Friday night.
neallewis is offline
Old 01-15-2015, 03:58 PM
  #146
neallewis's Avatar
Piston 1 = 2x 1.7mm
Piston 2 = 2x 1.6mm
Piston 3 = 2x 1.5mm
kit comes with a pair of each.
3k diff oil supplied. 300/400 CST shock oils. Enough for one fill.
Old 01-15-2015, 04:00 PM
  #147
neallewis's Avatar
Pistons are molded. they will work. clear the sprue off with a sharp knife, ensure its smooth and they will work fine. Sure machined are better, but i found the shocks the best i've ever built. The included pistons don't take away from it.
Old 01-15-2015, 04:15 PM
  #148
does anyone know if Losi pistons work on the shaft? and kyosho x rings?
Old 01-15-2015, 04:52 PM
  #149
STLNLST's Avatar
Trader Rating: 32 (100%+)
Can you get a 24mm ride height?
STLNLST is offline
Old 01-15-2015, 05:49 PM
  #150
Jack Smash's Avatar
Trader Rating: 35 (100%+)
One is up here in Reno. I got the body for some airbrush love last night
Jack Smash is offline
