Best servo 1/10 TC >
Best servo 1/10 TC
Best servo 1/10 TC
Old 11-09-2014, 10:58 AM
Salkin's Avatar
Default Best servo 1/10 TC
Simply, I want the best servo for my 1/10 electric touring car.
I have set on an Ko Propo.
There are the RSx one10 Response and the BSx2 one10 Response.
The RSx have a coreless motor and the BSx a brushless.
The BSx cost more than the RSx.
Is it worth going for the BSx?
Salkin is offline
Old 11-09-2014, 12:05 PM
Trader Rating: 11 (100%+)
If you can afford it, yes.
Brushless motors are better full stop.
cplus is offline
Old 11-09-2014, 02:36 PM
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
i really like the Sanwa SGR-BLS and SGR-BLS v2. this was my go-to servo until Awesomatix released their own servo!
hanulec is offline
Old 11-10-2014, 03:41 AM
Salkin's Avatar
Thanks for the answers.
The BSx2 one10 Response is quite new and I have read that some have problems with it.
Really wanting a brushless servo, counting out the RSx One 10, I bought the "old" well tested Futaba BLS551 instead.
The BLS551 is now replaces with a newer version (571 or something I guess), which is capable of running HV, but as I do not run HV in my touring car, the BLS551 will do fine.
Salkin is offline
Old 11-10-2014, 05:59 AM
I've got a 551. It's plenty fast/strong in a TC and takes a beating. Really good bit of gear.
Sadly superseded and the replacement 571 doesn't appear to do anything better apart from handling 7.4+V as you mentioned. I think it is a little cheaper though, so I guess that's a small win.
As far as I can determine, this is pointless in electric TC with current battery tech, we can't guarantee full 7.4V for a whole run (due to both peak draw and voltage drop), so performance of the servo would fluctuate.
cplus is offline
Old 11-10-2014, 06:21 AM
Salkin's Avatar
Yes, agree. Wonder if you could power the reciever directly from the +/- on the esc and have some small capacitor/regulator in between to provide a (more or less) stable voltage.
On mylaps I can see that my receiver receives a constant voltage of 5,8V from the esc, and even though this is not even 6V, it is constant through out the entire run.
Salkin is offline
Old 11-10-2014, 08:22 AM
locked's Avatar
I've been really impressed with the Xpert 3401 low profile servos, so far. I have a lee martin edition and a full aluminum case version. They have some of the best specs and aren't very expensive. Fast, strong and precise, without drawing a ton of power.
locked is offline
Old 11-10-2014, 05:16 PM
Warren Weaver's Avatar
Trader Rating: 49 (100%+)
Ame servo is the best,I used futaba bls servos for years and i can definitely say the ame tops it
Warren Weaver is offline
Old 11-10-2014, 10:52 PM
I moved from ko to the sanwa bls v2 to allow the SHR functionality of the Exzes Z I bought. It's stunning, I've never had such a smooth and precise servo. Still have a soft spot for KO but can't see myselft changing this combo.
Qatmix is offline
