After Run Oil?
After Run Oil?
Just curious to find out what brand after run oils you guys use? I've heard some guys use Marvel Mystery Oil (mixed with automatic transmission fluid?...50/50??)...does anyone recommend this? And is it true that it is bad to drop the after run oil into the carb...i heard it eats up the orings?
Thanks for the help in advance!
If you go and buy after run oil, it will almost always be pink - which means it's Marvel! heh heh.
I just use Marvel straight.
All you're trying to do is to get a coating of oil on the piston, sleeve, rod, etc. that will be water repelling rather than water attracting. Any decent oil will accomplish that.
I don't know about putting it in the carb. I make sure my fuel lines are empty then pop about 4 decent drops down the glowplug hole and then crank the motor for a few seconds to splash it all around.
dunno about you guys, but i'm always having a hard time starting up the engine if I've used some after runs.
here's what i do (taken from a pro advise), when you're done for the day, clean the tip of the muffler, then put the air compressor on the exchause tip and blow it. the excess oil from fuel will be blown back to the engine, that'll sure cover every part of the engine from rust.
that is danger !! never let any thing go into the engine without a filter(either fuel or air filter) i am sure no one want wasted oil reaching their engines.
Redsand
Just look at your site. those tool boxes are cool ! do you ship them to Hong Kong?
Firstly its that fuel and oil that your trying to eliminate because its hydroscopic ( absorbs moisture ) and corrodes your engine !
You don't won't to blow it back in after you just ran it dry
And what about all the carbon deposits and grim that builds up in your exhaust, don't think you'd want to blow that back into your engine in a hurry
I would be VERY wary of taking ANY advise from this "Pro" driver if he is telling you to blow crap back into your engine!!
I`ve used Marvel Mystery oil for 25 years with no problems ever. Hell I`ve dipped clean motors in a can of the stuff,then pulled them out and stuck them in a container for storage. P.s. No way in hell would I blow any thing back into a motor.
NEVER blow back with an air compressor. Pipes get filthy and in an offroad situation you can bet there's dirt in there. marvel Mystery oil is the best after run and it's very cheap, a few bucks for a quart at Checkers. I usually remove my motor at the end of the race day and clean the exterior. I'll then remove the backplate and flush the insides out with WD40 to displace moisture. I then put a mixture of engine treatment/Marvel Oil (a tablespoon to a quart) and lube the insides and drop it into a ziplock bag for the next race. I find my motors always run extremely well and last for years.
I agree completely - don't blow crap back into your motor! Crap=baaad!
Pretty much any good clean oil, though, is going to displace the fuel that is bad to leave on the guts of your motor. Shoot, you could prolly use 30 weight. . .
My LHS sells "Prather After Run Oil". I see all the other racers at my club using it, so that's what I bought. No complaints so far.
If you race every weekend, you don't need after run oil. If its more than a week or two between races put 2-3 DROPS of Marvel Mystery oil in the carb. Your engine will stay lubed till your next run.
Well that may be true where you live, it is relatively humid where I live and things rust real fast. But any after run is much better than none
Originally posted by Manticore
Redsand
Redsand
We currently do not ship to International addresses.
