Pro 4 Hara Edition
Pro 4 Hara Edition
Hello there people,
i was building the kit and i will be using a softer spring setup but the weight of the oil that came with the kit is 50 weight and i would like to use 40 front 35 rear . What brand of shock silicone oil do you recommend cause i have the trinity and team associated in stock but don't know if the rates are compared to the HPI one.
associated's oil is probably some of the best stuff, dont know about trinit'ys oil. I run only associated's oil, never had a problem, always consistent.
Hi Speed 6 I would try Xray oils .... they are the most consistant oils i have used these past few years ....you should contact your local distributor who should provide you with them .....
See you at the the track Gus
