New to RC any need tips
#46
I am going to try to give you the best advice...
Go to the track that u r planning on practicing and racing. Bring a pen and paper... Ask about the classes. As someone said do they have a stock class or boosted class... This will determine what esc u will purchase....this class is typically 17.5. Watch them run and see if u will like that speed... As a beginner u will break less parts with the slightly slower classes, but do what u want. The Justock esc is a great esc for the money... I had one... Falconsekido.com sells them and will double the warranty. They might even sell a combo for about 90. I am not sure about the hobbywing motors. I like the hobbyking track star motors... I used it with the justock esc... If u are racing boosted then u will need a different esc..... Before u build your car u must get two hex drivers. I believe u will need a 2.0 and 2.5 mm...please check te manual... I do not own a sakura......buy two quality hex tools...Mip or Hudy is good. Do not use the tools with te kit. U will strip the screws. Go to hobbypartz.com and order the 6.0 amp ac/dc charger. It's about 50. Futaba or airtronics transmitter.....u can always get help. I buy SMC batteries. Cheap and very very good. U could get away with one at first, but two would be better..... U need to ask at the track what milliamperes u need......too many and yor car will be heavier...too little and u won't finish races.... Ask as to what tires u will need..... U will learn so much by going to the track on a race day...go early.....or practice day... Good luck.
Rookie/Intermediate Sedan
Rookie-Intermediate 17.5
ESC: No-Timing, No-Boost ESC (ROAR Approved Non-Timing ESC)
Tire: Sweep QTS32 Real Blue Premount spec tire. Click Here
Motor: 17.5
Battery: 2s Lipo
#48
I've been searching for prices for Futuba 3pm and i've came up with these 2 with big diffrence on their price. the other one is listed with FASST system and the other one doesn't. this is the first one
http://www.ebay.com/itm/NEW-Futaba-3...item43ce9c0372
and here is the second one
http://www.rcmart.com/futaba-channel...ml?cPath=36_47
they have an 80$ difference. i'm not sure if they are basically the same or i need to buy the more expensive one? can anyone please help me. tyvm
#49
between futaba s9551 and savox 1251 which one should i choose? what are the pros and cons. tyvm
#50
#51
#52
how's your build going?
#53
I do not have everything yet. I am in Pasadena and I was planning to race at Tq too. Was thinking of stopping by next weekend to check things out. Have you been there yet? What equipment do you have/will you be running? I'll probably be in the novice 17.5 class too so maybe we can race together in the near future!
#54
This is my budget build once finished(well, i'm trying to really lower down d cost for my first one. Need a lot of practice first before buying expensive stuffs)
Kit sakura xi
Motor turnigy trackstar 17.5T
Esc hobbywing justock
Servo savox 1251
Transmitter futaba 3pl
#55
The savöx 1251 servo is not quite durable, as the gears tend to strip in a crash.
Futaba servos may be the better investment, but you can also consider a servosaver like the xray x-stiff servosaver
#56
#57
any suggestions for a cheap but good lipo battery charger and power supply? tyvm
#58
#59
Accucel 6
With this p/s
http://pages.ebay.com/link/?nav=item...637229&alt=web
This setup will be fine with almost any 2s or 3s. If your charging a 2s batt above 6 amps then your diminishing it's life for a faster charge anyways which I don't do.
With this p/s
