VBC WILDFIRE D07
#212
Question about the D06 shocks ... My rear shock springs are loose between the spring cups and the adjustment collars when the arms are at their full droop. It's like the springs themselves are too short?? The shock end connectors are fully screwed on... Any help? Thanks!
#214
#215
Just check a few things:
1.) Overall length of the shock should be 59.0-60.0mm. I generally stick to 59mm since it makes the car feel more direct from increased pack. A lot of times when you
2.) Have there been any modifications to the shocks or shock towers to accomodate longer springs (like Yokomo or HPI)? This forces you to crank those preload collars almost all the way down when using the kit VBC TBB short springs.
3.) If those first 2 things have checked out, A little spring float is normal at full droop extension when using 3.0+mm or droop and stiffer springs.
If you still aren't totally convinced, post a pic of your car while sitting at ride height and a pic at full droop so we can take a look see.
Hope that helps!
-Korey
Hope that helps!
-Korey
#217
70% done up for mine.
Would be sharing up the build pics on https://www.facebook.com/teamvbcracingsingapore soon.
#218
Anyone using a servo saver ? If so which one?
#221
#222
How are the shocks and diff quality in this kit? Do they leak much???
#224
Does anyone have any info on the Active rear toe kit that was supposed to be coming?
#225
