What engine you are using on your 1:8 on road?
The XRC are LM/Sirio based
Smaller number = softer shore ratings, may or may not wear out faster though, mainly because you can strike conditions where the hard shore foam just spins and chews out faster, where the softer grips more and may wear the same or less, not always the case, but sometimes.
Vox, Reds, Sonic, all Picco based.
RB is Nova based.
New XR Cap motors are OS I think, as is Zac motors.
RB is Nova based.
I see many people use different numbers of foam tires front and rear, why?
if different brands comes from same manufactory, that means the performance will be nearly same?
For the engine, i only have them from RTR cars. One is this VOX V1 from P8F CLUB, and the other is from X3 RTR. It is Taiwan engine.
Don't know other brand performance if they are coming same producer sometimes.
People mix and match shores to dial in or out ability to turn, and even out wear front to rear, much of that can come down to preference and what your chasing.
As an example one person may like very sharp steering, lots or turn, so may run 32/35, another may like just that bit of push or understeer entering a corner before the car turns, so may run 35/35, it's tuning, although you can alter the cars to do the same, but often people tune with tyres for reasons of wear and to suit the track on the day.
Having said that, they often are fairly close to how they make power in the end.
#20
Sort of, it depends on the amount of grip or bite in the track, too much traction and too soft a tyre shore will make the car twitchy and traction roll etc, also it can make the car hard to turn with too much traction in the rear.
Not always, the blocks and most all parts come out of the same factory, but the brand selling them will usually 'tune' or modify them to produce power in the way they want it to, torque and power curves etc.
I think for the tires, i need many times to try with my car.I am now use both 32, i found it is really short time use, costy a lot...The car really has much traction. I will try other hard tires.I will buy different numbers of tires to try.
Many thanks!
#21
Oh, i have also want to ask you about the glow plugs use.The original my engine is with P6TC, but they also have different numbers of glow plugs, such as P5Tc, P7Tc. What is the difference of the numbers?
#22
If there's lots of O2 in the air (sea level cold climate) then you need more fuel, so you can use a hotter plug (generally lower numbers) if you run in hotter climates where O2 in air is thinner and less fuel in the mix, then a hotter plug may pre-detonate and you "ning ning ning" at idle and risk overheating engine as there's not enough fuel to cool it down at idle.
Also plugs have an impact on ignition timing, the more you (Edit: I'm wrong with this it should be retard with a cold plug) advance ignition with a cold plug, the more top end power. Use too cold a plug and you'll struggle to get it to idle well and your LSN mixture and idle will be out and your car will over run.
This might make you laugh, I wrote it to have fun but needs editing, it was rushed.
http://racing.beachmums.com.au/rc-ni...de-to-farting/
#23
O.S. Speed R2101 or Virtus.
#24
Oxygen in Air compared to Fuel ratio.
I found myself started to learn more about engine.
Feel rather complex with the engine. They are more difficult than electrical...
For the glow, can i use other brands glow plugs in my vox c1?
It is not easy to find vox engine parts.
#26
VOX V2 is a good choise
Need some suggestions on the engines as i want to change my old engine in P8F club.It is rtr vox v1 tech engine not pro. As far as i feel ok for it.I know it is picco production. I see they are now having VOX V2 pro. Or maybe i should also change another car? need some suggestions before i spend money.
#27
Yes, the car is Motonica P8F club.It is a gift . I am not the who race competitions,it is just my hobby.Very interesting, so i would like to know more.
This car is w/o suspension.Yes i still want to keep pan car. as i see if i change to their P81RS3 with VOX V2 PRO will be much cost for me at the moment.Even i know they are professional racing car.
BTW, i also want to ask about how to choose the foam tires. There are many numbers of the tires.any different? and any different between the carbon and white light rim?
Many thanks!
Many thanks!
