Nitro mini chassis
It would have to be a RWD 2WD direct drive chassis to make it work with tank and steering shifted forward which then gets in the way of steering columns and such. Then by usuing a smaller engine, it makes it more complicated and more expensive overall.
Why not consider a 200mm track width IC pro tourer and get a larger mini shell, they're a dime a dozen and will be better value in the long run.
PS: Havent seen the HPI car, I'm working from experience in 1/10th scale pro touring and the complications they pose.
You'd have a hard time getting everything in place for a short wheelbase like that if it's 4WD. We can barely pack everything in 1/10th scale tourers and we mount engine transversely.
I actually have a mini nitro RS4 along with its electric chassis sibling. Found the nitro one in a local pawn shop (had top plate and front half of the rolling chassis, missing the rear half) for $10USD. Since the majority of the parts outside of center belt is the same of the regular RS4 (which I have tons of parts), the rebuild was a breeze. It is a fun little car but don't put too much power in it or becomes a tumbler (very uncontrollable).
I asked because I saw one of the hpi mini rs4 at my track and thought it was cool I have never seen a nitro mini, I only seen electric one. When I got home I look up the mini rs4 and saw how hard parts for it are to find that way I asked if there are any mini nitro
blis,
Wow, they fit it all in there some how!!! It's a cutey and I expect you really have to love RC to keep it maintained, I struggled to see the belt and there it was, hidden under the top deck.
Must say it's impressive a design to pack all that into such a small chassis. Just saw the other side in a different pic and the short side belt.
You learn something new every day!
I've never seen one so it was hard to believe we could get smaller than 1/10th, I'll Google it and have a look at the layout as now I'm interested in seeing how it all fits.
I have stocked up on a few parts over the years. Luckily, the bulkhead and diffs are the same from the regular sized RS4/RS4 2/Racer/Racer 2 so you can still find a few of these parts in LHS bargain bins. The arms are shared between the electric mini. You can use the rims, tires and bodies from the Tamiya minis and even the dogbones in a pinch. The rear belt is the same as the regular-size RS4 so the only thing is trying to get the center belt that drives the front diff.
tumbled like a boulder down a mountain-side.
I can you give you a hands on looksy if you like. Abbey has one brand new in the original box.
Speed Chaser: Kyosho have made one too from memory, remember a guy at the original Wynnum club had one he use to race against our Kyosho V-One S. Funny thing was it was the same as the real deal and quick through the corners, but we had an advantage on the straights.
Andy, would love to catch up with you before we head to Thailand...
Xray has a mini nitro car, that have many of them here is a link to there XRAY NT18
http://www.teamxray.com/teamxray/pro...p?prod_id=1610
and a link to other cars:
http://www.teamxray.com/teamxray/ind...773a7526fff15a
I had the micro x-ray nitro sedan and I could stay with the 12th scale cars on the pavement. I couldn't get more than 4 1/2 minutes run time though.
