XRAY X12 - 2015 Specs
The only thing some complained of was there is definitely more slack in the front steering joints at the uprights, but the car drives fine with that.
Haven't had to replace ans single part on the Xray since I bought it. The mirror opposite of my CRC
2015 All-New Specs
All-new orange aluminum parts
All-new center shock position adjustment
All-new 1-hole piston
All-new steering block
All-new bumpsteer shims
All-new upper arm position adjustment shims
All-new composite lower and upper pivot brace
All-new pod pivot ball
All-new rear link pod upper plate
All-new shock adaptor
All-new rear link brace
All-new composite battery backstops
Team EAM
Not all the parts will.
These I know will:
Steering blocks
all the orange alumn pieces
1 hole piston
bump steer shims
pivot socket and ball
upper arm shims
I am not sure about the other stuff until I get my final production cars. The preproduction stuff is slightly different than what was released.
EA
These I know will:
Steering blocks
1 hole piston
bump steer shims
upper arm shims
EA
The two upgrades I would do from the factory kit is switch to a carbon rear axle and a better center shock. The regular XRAY shock leaks and goes through bladders a bit more than other shocks. Also, the selection of springs is limited with the stock shock.
I also come from the CRC and I can tell you, I like my X12 '14 so much more. I will have a tough time reasoning the upgrade myself to the new car.
#20
We stock most of the X12 items at Reflex. I would say that if you need anything extra is the steering blocks, outside of that I have not seen any breakage and about 60% of our locals run the X12.
Derrick
#22
Yes, the hot bodies shock is very nice, but unfortunately discontinued.
We sell the Team Prime shock, which is very nice, but the Silva Concepts, CRC and Kyosho shocks are a good alternative as well. I believe IRS sells a pretty good one too.
We will have more Team Prime shocks in about 10 days. It is really hard to keep them in stock, but I know Apex RC ordered the last of them from us and should have them in stock before then.
#23
I really like the CRC shock and ran it on my BMI before I started running CRC cars. But red with all that orange...not sure I can do that Might have to get one re-anodized...LOL
#24
#25
What servo(s) is the chassis drilled for to get perfectly centered alignment?
#27
https://www.facebook.com/pages/Zen-R...563679?fref=ts
http://www.zen-racing.co.uk/catalog/...-products-c-25
#28
Perhaps you should look into distributing Zen Racing products;
We'll take a look at it again soon.
#30
