Advance R/C Car R10 2015 >
Old 08-22-2014, 12:03 PM
  #76
Originally Posted by Carnage9270
In order to get there with a 96T, you will need to grind the motor tower a bit.
Here's a pic of the area to grind.
Attachment 1225616
You only need to grind out the area where the pinion will touch the tower. Its actually a fairly narrow area and the screw attaching the motor bulkhead does not pass deep enough into the area you grind.
Thanks, but I guess I'll look into using a 88t spur then. Don't want to grind the black...lol
inpuressa is offline
Old 08-22-2014, 12:06 PM
  #77
Yeah definitely go smaller to avoid the silver grind marks. Can always touch it up with paint as well. Can barely see it in there with the pinion on.
Carnage9270 is offline
Old 08-22-2014, 12:28 PM
  #78
Is 96/55 the limit? will a 96/54 fit with no mods?
Old 08-22-2014, 12:30 PM
  #79
I've already ground mine out so I couldn't tell you what will fit without grinding. If I remember correctly though I don't think you'll even be able to hit 4.0 on the FDR with a 96 spur. Hopefully a fix is on the way for larger spur pinion combos. I think the US is the only place we really use the larger combos.
Old 08-22-2014, 12:31 PM
  #80
AOD
AOD's Avatar
Oh no you didn't.
AOD is offline
Old 08-22-2014, 12:33 PM
  #81
Originally Posted by AOD
Oh no you didn't.
crap, they found me
Old 08-22-2014, 12:40 PM
  #82
nikos2002's Avatar
Trader Rating: 30 (100%+)
We have already spoken to ARC and they have looked at the situation. From Europe and Asia, where they have had a bigger following until recently (thanks everyone!!!), they don't see 17.5 classes, so they were not aware of the gearing situation. But they will be working it out shortly for the future. They have always been quick to respond to ideas and feedback.
nikos2002 is offline
Old 08-22-2014, 12:41 PM
  #83
nikos2002's Avatar
Originally Posted by Josh-n-ya
Hey Nick, can you post up when the upgrade kits are in? Might just give it a try. thx
Should be here next Tues/Wed
Old 08-22-2014, 12:46 PM
  #84
48pinion will give you 4.0, I guess 47 would be the largest.
So I guess 143tooth count (47+96) would be the pinion/spur combo limit.
My next issue is to find out how close can the motor get to the spur...
Would be nice if there was a gearing range chart with this motor mount.
The only way they can offer a fix is to give us a redesigned tower...
I read on some asian racing forum, and the general consensus is that boosted is the way to go. Where did this split happen?
  #85
nikos2002's Avatar
Don't think it was officially announce in here ----
ARC will be a proud sponsor at Scotty Ernst's IIC event in Las Vegas this year. Anyone driving an ARC car at the event can come by and pick up a race support package from us. Meet the factory engineers and the US support staff.
ARC will also be have factory drivers from Europe and Asia attending the event as well. To help work on set ups and show how well the car can work on carpet.
Also expect to see many of the ARC USA team drivers attending the event as well!!
Old 08-25-2014, 11:08 AM
  #86
This car...
What can I say? It continues to be the most consistent car I've used yet. Transitions through chicanes, predictability...everything I throw at it...doesn't blink.
Raced on a very wide open track this last weekend and the car was flawless...my driving, not so much lol. The car is really picking up a following up here in the Pacific Northwest and people aren't looking back. The car took 1st and 3rd in 17.5 blinky and 2nd in our slightly modified version of VTA. These people haven't been racing the car long and it still performs well.
Putting together my Black Edition this week, I'll try and throw some pics up from the build process when I'm done.
Old 08-25-2014, 12:13 PM
  #87
Got my black edition in today. The box was nice and small.
Started on the usual chassis prep, sanded the CF edges and CA'd the bottom plate.
The diff went together smoothly, but did some adjustments on it.
1. The sun gear, as noted on the instructions in petitrc, sanded to 4.18mm. The gears were 4.20, 4.22 out of the bag. Be sure to carve off any flashing.
2. The plastic cross pin may need to be sanded a bit to make the gears spin smoothly.
3. The large diff shim has a rounded and a straight side. Put the rounded side facing up. There are some sharp flashings on the shim too. Sand it down to make it smooth.
After doing these steps, I got a super smooth diff. The precision is top notch, one of the best I've built.
Will be working on shocks next.
Attached Thumbnails Advance R/C Car R10 2015-20140823_153403.jpg
Old 08-25-2014, 12:39 PM
  #88
nikos2002's Avatar
inpuressa - glad you like everything!!!
Carnage9270 - Mike - who won? How did you do? Where is racing next weekend????
Old 08-25-2014, 04:13 PM
  #89
Josh-n-ya's Avatar
Trader Rating: 95 (100%+)
Things you will notice about the diff is they never leak. I have had the same large o-ring in my diff for over a year. Lol. I sanded the smaller gears slightly more and have two shims on the backs of those. Way smoother.
Josh-n-ya is offline
Old 08-25-2014, 05:59 PM
  #90
This car...
ahem. that would be my car that placed 2nd in (vta) scale spec. only beaten by a guy that races there all the time (his home track). but for its first outing it did very well. once i fixed an oops in building the car, it was really good. i ran another car tc 6.1 in the first 2 quals then the arc in the last qual and was about 3 sec faster in the last qual with the arc. still needs some tuning but out of the box the car was very good.
I am planning on adding the low friction belts and pulleys to further reduce drag. car is very predictable and very smooth.
dragonracing is offline
