Speedmerchant Roadkill 10 235mm Pro10 Pancar
#31
Isn't a front brace necessary with this car? Most 235mm cars do use one.
Which pod inserts are used to change ride height in the back?
I hope they are metal, not plastic.
Don't see them on the Speedmerchant website....
Same as to changing ride height in the front.
Which centre shock springs? Looking for them on the Speedmerchant website. Not found them yet. My bad...?
I prefer standard BSR tyres all around. They go with this car with no problems?
How do you change caster with this car? Maybe with the two screws on top of the front suspension and than move back or forth?
#32
RK10
@Speedmerchant
Are there different/several ride height bearing holders for adjusting the ride heigth in the back in the kit?
If not, which part numbers on your website do I have to order?
Springs for the centre shocks? Please provide part numbers.
And as to spacers for adjusting ride height in the front?
#33
Part #1875 Description Retail Price Sale Price
smr1875 1/10th Scale 235mm RoadKill 10 Competition Kit
Features:
1/10th Scale 235mm RoadKill 10 Racing Chassis
The Original Link & Spring Speed-Tune Racing Suspension
SpeedMerchant Linear Tweak Springs (.020 included)
Aero Space Grade Carbon Fiber Components
Exclusive SpeedMerchant Damper Tubes
New Low CG Black Anodized Laser Inscribed Aluminum Pod Plates
Stainless Steel Hardware Through-Out
HPS Teflon Coated Super Shock (Black)
Exclusive SpeedMerchant New School Front Suspension
New Black Anodized Laser Inscribed Front Suspension Mounts
New Black Anodized Aluminum Steering Blocks
Hardened Steel Front Axles
Servo Mounts With Hardware
New Long Molded SpeedMerchant Side Links
Adjustable Roll Center
Adjustable "Rear Steer"
Transverse or In-Line Battery Placement
1.5" Inches of Battery Weight Bias using a Brick Pack in Transverse Mode
Kit Includes TWO Shock Mounts for Brick or Stick Pack
Optional Carbon Fiber Front Bumper Included in Pre-Order Kits
$245 Price reflects NO Axle Included
Only 10 Available - Good Luck
Needed To Complete The Kit:
Electronics/Radio System
7.4 Brick Pack or 7.4 Stick Pack
540 Base Motor
Tires/Wheels
1/10th 235mm Body
Medium Servo Saver (upper/outer holes for correct Ackerman)
Steering Tie Rods and 4-40 Plastic Ball Cups
235mm Axle/Diff Set (IRS#2135 Suggested)
$495.00 $245.00
Features:
540 Base Motor
Tires/Wheels
1/10th 235mm Body
$495.00 $245.00
#34
Features:
540 Base Motor
Tires/Wheels
1/10th 235mm Body
$495.00 $245.00
Features:
540 Base Motor
Tires/Wheels
1/10th 235mm Body
$495.00 $245.00
#35
Thanks. New and proprietary are good words to remember for this car.
Center Shock is right off the Rev 8. It uses the same diameter center spring as the old center shock.
New School Front End: http://www.teamspeedmerchant.com/sho...l/smr7020.html
This front end and chassis isn't going to flex much and has caster adjustment. Simple shim to ride height setting. Very cool! It's going to be on my car! I'm so pumped! There is good reason it is sold out.
If Team Tamale rear pod plates work for this car, they could be my first upgrade. I think I better run it out of the box for little while though.
My final thought for now. If the team/mfg. is good enough for Josh to win 5 events on his first drive for SpeedMerchant, his mad design skills and experience with Bruce's infinite know how and get it done attitude, this car cannot be a failure. It is truly a piece of rolling art and a true evolution in pan car design.
#38
#39
Judging by the stout design of the new school front end design I would wager that there will be no need for a brace up front unless you like to crash hard lol.
This thing looks "hopped up" out of the box, with the aluminum pod plates and the fact that they choose to design the rear pod to use an IRS axle makes it an instant winner in my book. An aluminum left pod plate and IRS axle are upgrades for most box stock pan cars.
I can't wait to see these bad boys hit the track, they should be rocket ships on rails!
#44
Patience... Must have... patience.
Most everything else will be in by Friday.
http://www.teamspeedmerchant.com/news.html - Now Sold out, shipping within 2 weeks.
