Xray t4'15
#151
#152
#153
I really want to see Xray make a purpose build shaft drive car for VTA. A fiber glass version with Xray quality. However good, the TC4 is out dated and the all the newer model are not designed well for lower speeds, tires & roll center. With the popularity of the Awesomatix, I really think the market is ripe for such a design and marketed for VTA.
#154
#155
NT1 2014 shocks
NT1 2014 shocks , Yes please , have been using them the last 14 days on low/medium grip asphalt , super easy to drive , and better lap times. Raceberry towers and Yok pink springs
#156
Yes, but I found adding a 2mm spacer on the shock shaft, inside the shock, helped with the preloads. They are about that much longer than the t3 shocks, otherwise a perfect fit. I should say, that's with the Bezerk RC towers, I've not tested any others.
#158
And for comparison, what springs, oil and pistons were you using on the standard T4 shocks?
#160
That's quite a lot of damping, might be why it was struggling for grip with the short shocks. When the grip is med/low in the UK I run 350, if the grip comes up I go to 400. Thats with 4x1.1 pistons. I've tried going thicker when the grip is low and it always goes slower and feels horrible. Have you tried going thinner?
I have the Raceberry towers and a set of T3 alloy shocks, I don't find them any better than the short shocks (they were going cheap so it was worth a try).
#162
#163
And the tease is on
#164
An announcement about an upcoming announcement
#165
