hpi rs4 3 w/ os18cvr
has anyone tried this combo having trouble with engine mounts,
os18cvr
I have had that motor in both an ultima st, needed to buy aftermarket 3 to 4 screws engine mount.
Then after quite a few spur gears have put it in a vones, destroyed the 2speed with to much torque. But was quite easy to bolt it in with same engine mount from offroader
You don't mention what type of problems you are having. You can't find engine mounts that work? Not lining up right? Not staying mounted properly?
I'm not sure, but i believe the rs4 3 was a rtr. In which case you didn't get any engine mounts with it and probably came with their nitrostar .15. Yes?
I am not well versed in this model exactly. Several buddies have rs4 versions and all have put other manufacturers engines in them. My son has the MT2 and I am in the process of building an MT Racer. After looking at HPI's website, all appear to have about the same platform on which they were made. Someone I'm sure will correct me if I am wrong.
I am putting an O.S. .18 cv-r in mine. It screwed right in with the mounts they provided. Here is the line just as it reads in the manual:
A863 2 Engine Mount (HPI, OS) 4.00
The price might not be the same. It's from 2002, but I hope this works for you. I haven't ran mine yet, (still waiting on some parts) but it looks to be lined up good. Good luck.
Rowdyray
Rowdyray
