Team Associated T5M Discussion
#3301
Hi guys, been searching with no luck. Question is, Has anyone successfully adapted a B6 laydown Trans to a T5m?? Thanks.
#3302
Just use the one from shapeways, works great
#3303
B6 stuff doesn't bolt on to the 5 series. There are other ways to get a laydown transmission in your truck.
#3304
Just don't trust 3d printed ones, used the first Redworks on my b5m and it didn't last long, started skipping gears. Got the WWHD after that and it was rock solid, but can't find another one anywhere.
Know it would not be a direct bolt on, but was just wondering if it was possible.
#3305
#3307
hey new to the t5m ran my first race with it i run in lose dirt i had the setup 26/78 in it as it suggested and it came off the track after 5 mins at 167 went down to a 24 and it still came off at 160 and i was getting passed like i was sitting still
#3312
The regular springs always give a more comfortable feel. I have no trouble running the newer truck springs in any indoor track regardless of grip. The only time the don't feel good is in bumpy conditions, I can't run them outdoors.
#3313
Can you use SC 2.2/3.0 tires on a T5M?
Hello,
I was at the RC store and the sales guy insisted that the SC 2.2/3.0 hole shots tires are the right wheel for the T5M. When I got home and compared them to the current tires on the truck they are obviously narrower and larger in diameter than the tires on the truck. The store is almost an hour away so returning them is unlikely.
Can I run SC tires on a T5M? What would the offset have to be as they are narrower than the stock tires?
Nate
Nate
#3314
You technically *could* run them but I would suspect the handling would be whacky to say the least.
#3315
Hello,
Nate
Nate
