Team Associated T5M Discussion
#3092
I am using Speedy's Racing Parts slipper eliminator and the cut gears and I haven't had any problems with idlers failing. Now I oil my bearings so maybe that helps? The Ohio RC Factory is extremely high bite at times.
My truck is quite a bit lighter than most as well. I'm a little above 1800 grams so that probably makes a difference.
Blake
Blake
#3093
Question about T5m rear body clips coming off????
My buddy said his do and I remember when I ran my T5m it happened to me a couple times.
Is there any solution besides keeping the "rubber side down"?
Does it happen to you?
What is ur solution?
#3096
R/C Tech Elite Member
#3098
#3099
I had a problem with loosing way too many clips. When I took a closer look I noticed that the body mount posts were split above the clip home and the clips we're actually pulling out of the top of the posts. Since replacing the body mounts with new original parts it is really rare for me to loose a clip.
#3100
Tech Prophet
